Giordon G3 "Warning for roadside stop"
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39901
Printed Date: April 18, 2026 at 7:48 PM
Topic: Giordon G3 "Warning for roadside stop"
Posted By: karemort
Subject: Giordon G3 "Warning for roadside stop"
Date Posted: September 28, 2004 at 9:13 AM
Annybody nows how to disabele the "Warning for roadside stop"
Light flashes when open door
And the small wire loop on the right side, what is that????
Posted By: karemort
Date Posted: September 28, 2004 at 9:15 AM
Posted By: karemort
Date Posted: September 28, 2004 at 9:19 AM
Annybody nows how to disable the "warning for roadside stop"
(light flashes when open door)
And the small wire loop on the right side, what is that.
Posted By: ywdb
Date Posted: October 04, 2004 at 8:50 PM
Hi,karemort:
Giordon G3 alarm's "warning for rodeside stop" function cannot disable.
Giordon 2-way alarm can be select this function.
Small wire loop...This is select of doorlock/Unlock signal time(0.8sec or 3.5sec).
If your vehicle doorlock is electric doorlock type, keep this wire loop.
If your vehicle doorlock is vacuum operated doorlock type, cut this wire loop.
Good luck!
