neon 99
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39931
Printed Date: April 18, 2026 at 8:05 AM
Topic: neon 99
Posted By: pedro lira
Subject: neon 99
Date Posted: September 28, 2004 at 4:30 PM
i need information of alarm original neon 99
Posted By: Teken
Date Posted: September 28, 2004 at 4:35 PM
DIRECTWIRE™ WIRING INFORMATION - DODGE / NEON / 1999 / Remote Start
12volts red & pink/black    +   ignition harness
Notes: SRS airbag wires are not enclosed in sheath at the steering column. They are a twisted pair run with rest of ignition harness. Be careful not to cut or probe these wires.
Starter yellow    +   ignition harness
Second Starter
Ignition dk. blue    +   ignition harness
Second Ignition
Third Ignition
Accessory BLACK/ orange    +   ignition harness
Second Accessory
Keysense
Power Lock ORANGE / purple   5wi taped harness from driv door
Power Unlock pink/purple   5wi taped harness from driv door
Lock Motor ORANGE / black      drivers kick
Unlock Motor pnk/wht or pnk/blk      drivers kick
Parking Lights+ BLACK / YELLOW      at headlight switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger yellow/black    -   behind headlight swtch
Dome Supervision
Trunk/Hatch Pin gray/black    -   at light in trunk
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer tan/blu or blk/gry      top motor 3 pin plug
Wait to start
Brake Wire WHITE/ gold dots    +   at brake switch
Parking Brake
Horn Trigger BLACK/ red    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
Posted By: Teken
Date Posted: September 28, 2004 at 4:36 PM
Dodge
Neon
1997-1999
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   YELLOW
IGNITION SWITCH HARNESS
Ignition #1:
   D BLUE
Ignition #2:
   BLACK/ ORANGE
IGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3:
   N/A
Accessory:
   BLACK/ WHITE
Brake Light:
   WHITE/ TAN (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
   GRAY/L BLUE
BLACK # PIN CONNECTOR AT PCM *
Parking Lights:
   BLACK / YELLOW (+)
AT HEADLIGHT SWITCH **
Headlights:
   L GREEN (+)
AT HEADLIGHT SWITCH
OEM Alarm Disarm:
   N/A
OEM Alarm Arm:
   N/A
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
   * Powertrain Control Module (PCM) Located On Front Of Driver Strut Tower.
Dodge
Neon
1997-1999
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   PINK/BLACK & RED
Starter Kill:
   YELLOW
Ignition +12 Volts:
   D BLUE
Dome Lights/Superv:
   YELLOW (-)
AT ANY PIN SWITCH ***
OEM Horn:
   BLACK/ RED (-)
STEERING COLUMN HARNESS
Power Lock:
   ORANGE / VIOLET
BLUE # PIN CONNECTOR
Power Unlock:
   PINK/VIOLET
IN DRIVER KICK PANEL ****
Trunk Release:
   N/A
Alarm Input Wire:
   YELLOW (-)
Notes:
** BLACK / YELLOW (+) Wire Also Located In Black 8 Pin Connector In Driver Kick Panel. *** YELLOW (-) Wire Also Located In Gray 16 Pin Connector Behind Driver Dash. **** See Note #203 reverse polarity door lock diagram.
Posted By: Teken
Date Posted: September 28, 2004 at 4:37 PM
DODGE NEON 1999
WIRE COLORS LOCATION
12 VOLTS CONSTANT PNK/BLK or RED IGNITION SWITCH HARNESS
IGNITION 1 DK.BLU IGNITION SWITCH HARNESS
IGNITION 2 IGNITION SWITCH HARNESS
IGNITION 3
ACCESSORY /HEATER BLOWER 1 BLK/ORG IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2
STARTER YEL (+) IGNITION SWITCH
PARKING LIGHTS BLK/YEL (+) LIGHT SWITCH HARNESS
DOMELIGHT YEL (-) PIN SWITCH
PWR DOOR LOCK ORG/VIO DR KICK PANEL
PWR DOOR UNLOCK PNK/VIO (TYPE C)
TRUNK RELEASE
TACH SENSOR GRY/LT.BLU PCM DR STRUT TOWER
BRAKE WHT/TAN (+) AT BRAKE SWITCH
HORN BLK/RED STEERING COLUMN HARNESS
FACTORY DISARM
Posted By: Teken
Date Posted: September 28, 2004 at 4:39 PM
https://www.designtech-intl.com/Content/techsupport/documents/section04/note203.pdf
The link provided above address's your door lock system.
Regards
EVIL Teken . . .
