’00 Nissan Sentra Bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39953
Printed Date: April 19, 2026 at 2:22 AM
Topic: ’00 Nissan Sentra Bypass
Posted By: merlin12volt
Subject: ’00 Nissan Sentra Bypass
Date Posted: September 28, 2004 at 8:46 PM
I am hooking up a remote start on this car and need to know how to wire up the "at home" version of the 555U using a relay and 22-24 gauge wire. I know I should use the 555U but couldnt find one in the area and the customer is low on cash.
I need to know if the following will work?
85 + jumpered from purple on starter relay
86 -
87 wire leading to the cylinder wrapped 3 times
30 wire leading to key hidden under dash I am already going to cut the end of the key off making it nonuseable. I just need to know how to set this up.
I have done a search but no one tells you how to wire up the relay. Thanks in advance for your help.
Posted By: mo12v
Date Posted: September 28, 2004 at 8:50 PM
Make sure U have at least 4 - 5 wraps around key
86 - 12 volts +
MO
Date Posted: September 28, 2004 at 8:57 PM
how can I have both 85 and 86 setup as 12volt+ leads? the relay wont polarize and flip then please elaborate
Posted By: mo12v
Date Posted: September 28, 2004 at 9:07 PM
No elaboration...........Pin 86 should be Positive ( your Purple wire) and 85 should be Negative  OOOPPS
MO
Date Posted: September 28, 2004 at 9:11 PM
THANKS posted_image
