GM Radio & Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40056
Printed Date: April 18, 2026 at 2:02 AM
Topic: GM Radio & Remote Start
Posted By: nathan909
Subject: GM Radio & Remote Start
Date Posted: September 30, 2004 at 2:19 PM
I'm installing a new UNGO SR5000 alarm in my 2000 Astro cargo van.
I have read information here about the radio staying on after a remote start on GM vehicles. Some people have said that the radio will shut off after 15 mins. Can anyone confirm this? If not what trickery should I attempt with this model alarm.
Thanks For your help!
-Nathan
Posted By: mo12v
Date Posted: September 30, 2004 at 2:34 PM
Not sure on your question:
If U power the 3 ignition wires and the Accessory wire, the Radio will come on and shut off when your RS shuts off & when the RAPS times out
MO
Posted By: kgerry
Date Posted: September 30, 2004 at 5:22 PM
yes it will shut off after about 10 minutes by itself... or you can hook up the rearm to pulse the drivers door pin and shut it off as soon as the RS times out
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
