Jeep Liberty
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40165
Printed Date: April 12, 2026 at 1:41 AM
Topic: Jeep Liberty
Posted By: kerrys914
Subject: Jeep Liberty
Date Posted: October 02, 2004 at 1:32 PM
How do I remove the lower trim piece below the steering wheel? I am trying to access the BCM area and it is very tight. If I could remove this trim piece it would greatly help me.
I am connecting my factory disarm output to th elibberty with a 470Ohm resistor, I will connect it to the OEM wiring....CORECT?
Cheers
Kerry
karrys914@yahoo.com
Audi 2002
Posted By: draasch
Date Posted: October 02, 2004 at 3:14 PM
OEM Alarm Disarm LT GREEN/ ORANGE (-) AT FUSE BOX***
* BCM Located Behind Driver Dash, Left Of Column
*** OEM Disarm Requires A Ground Pulse Thru A 485 Ohm Resistor
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
