civic clutch
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40198
Printed Date: April 10, 2026 at 10:11 PM
Topic: civic clutch
Posted By: shawnterrell
Subject: civic clutch
Date Posted: October 03, 2004 at 9:19 AM
Can somebody tell me how to bypass the clutch in my 2000 civic si . I got the alarm and r/s installled but i dont know how to do the clutch . help is appriciated!
Posted By: profuse007
Date Posted: October 03, 2004 at 9:42 AM
blue wire, negative trigger. use relay
Houston,TX
Date Posted: October 03, 2004 at 9:53 AM
what blue wire? at the top of the clutch is a 2 wire switch(orange and black) where is the blue wire located?
Posted By: flynntech
Date Posted: October 03, 2004 at 11:10 AM
Is a normally-open push button switch held in when the clutch pedal is up. It's typically a grounded wire (negative trigger) Just get under there and look.
Date Posted: October 03, 2004 at 1:15 PM
is there a way where i can make the clutch switch open at all times without using a relay?
Date Posted: October 03, 2004 at 3:52 PM
oops, thinking the 2000 is the latest model.
-yeah, tie the black and oragne together.
Houston,TX
Posted By: xtremeaudio
Date Posted: October 04, 2004 at 4:51 AM
ON CLUTCH SWITCH HAVE 2 WIRE 1 OF THEM IS (-) AND 1 WIAT FOR (-) WHEN CLUTCH PRESS YOU CAN USE ANY (-) OUT PUT WHEN REMOTE IS ON THE BEST WAY I THING YOU NEED TO USE A DIODE . IF SOME THING GO WRONG WITH THE CLUTCH THE DIODE WILL TAKE CARE NOT GOING TO KILL YOUR ALARM
Posted By: slab42
Date Posted: October 04, 2004 at 8:46 AM
be careful not to start your car in gear, i did that...posted_image  email me at slab42ebay@hotmail.com for my schematics on how to interface a regular remote start with a manual transmission car.  also, don't bypass the clutch all together, just use a relay for when the remote start is activated.
Date Posted: October 04, 2004 at 5:31 PM
Thanks for all the help guys. i finished the install up yesterday and works perfectly. What happened was i had the black and orange and i think that that is the cruise control and then i looked up higher and the clutch senser switch was way up there and it was blue and black. Thanks for the Help!
