Factory alarm problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=4026
Printed Date: May 15, 2026 at 2:27 PM
Topic: Factory alarm problem
Posted By: 2xavier2
Subject: Factory alarm problem
Date Posted: September 28, 2002 at 4:36 PM
new problem- need help
Car: 1995 acura legend coupe w factory alarm
Alarm System:3300 alarm remote starter
Everything works fine doors lock/unlock w remote, remote starter works w remote, but sometimes the cars factory alarm will not disarm when doors are unlocked or remote starter is used w remote.
2xavier2
Posted By: djfearny2
Date Posted: September 28, 2002 at 4:42 PM
make sure you are connected to right factory wire and use this relay setup to make it work.
https://members.tripod.com/~onsite/DISARM_FACTORY_alarms.gif
Jon
Installer/Help Technician
---coral springs florida---
Posted By: Velocity Motors
Date Posted: September 29, 2002 at 10:00 AM
The Legend uses the UNLOCK circuit to also disarm the OEM alarm system. Make sure that the RS unit isn't programmed to auto lock or auto arm after the remote starter has engaged.
