2002 Honda Accord Remote Start Problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40314
Printed Date: March 28, 2026 at 10:28 AM
Topic: 2002 Honda Accord Remote Start Problems
Posted By: Adrnlnalex
Subject: 2002 Honda Accord Remote Start Problems
Date Posted: October 05, 2004 at 7:38 AM
what's up guys,  I am installing a Crimestopper RS900VI Keyless entry and remote start system. I am unsure of where to hook up the yellow/black wire for the (-) ignition or anti grind relay output.  What wire in the car does this hook up to and where do I find it.  Another wire i'm having trouble with is the green start activation wire.  where does this go?  the last two wires i'm unsure of is the ORANGE / black wire for the OEM diarm, and the orange OEM rearm wires.  The install directions have me a little confused.  Also This is my first install so please if my questions are a little amature I apologize
Jason
Posted By: audiopro111
Date Posted: October 07, 2004 at 12:11 AM
the yellow/ black goes to a relay that u will have to set-up and most installation manuals will show u a diagram on how to do it ,and once u do that it will go connected to your stater wire 'now the green wire i'm not to sure because of the way u described it i don't know if it's positive ,negative or if it an activation wire for an external source,next we go with arm & disarm this only applies if your vehicle has a factory alarm.....in other words does your vehicles car horn beep if you open the door from the inside rocker or lever (you know the little thing that goes up or down at the edge of door to show u that it's locked or unlocked) with out unlocking it from your factory keyless entry remote or your key from the outside? If it does than you definitly have to hook up these wires to:arm to lock disarm to unlock   EX MODELS ONLY
AudioPro111
