Prestige APS875A - cranking time problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40319
Printed Date: March 28, 2026 at 7:26 AM
Topic: Prestige APS875A - cranking time problem
Posted By: dalmyd1
Subject: Prestige APS875A - cranking time problem
Date Posted: October 05, 2004 at 11:11 AM
I just installed the aforementioned alarm in a ford super duty f-250 DIESEL.  I'm need to extend the cranking time on this, but it doesn't say how, or if I even can.
NEED HELP ASAP!!!!
THANKS GUYS!!!!!!
Posted By: bdl666
Date Posted: October 05, 2004 at 11:48 AM
Posted By: sordee
Date Posted: October 05, 2004 at 11:50 AM
what year of ford and where did you get tach?
Posted By: dalmyd1
Date Posted: October 05, 2004 at 7:23 PM
I've already changed option#9 to Diesel 10.  It remote starts fine except this morning (first attempt of the day).  It seems like it needs a longer cranking time.  It's a 2002 and I got the tach in the PCM (white wire).
Posted By: audiopro111
Date Posted: October 07, 2004 at 11:58 PM
check how long it takes for  the glow plug light to go out on your dash once u turn the key to the on position not crank usually  the chillier it is outside the longer it takes ,just set feature 9 to diesel 20 that 3 flashes on your parking lights; another thing i've experienced on these trucks especially in the morning on colder mornings is if the vehicle has a transponder type key is that u should tape the ring snuggly around cylinder and grind down plastic on key a little to expose chip a little more.Be carefull not to grind too far or you will damage chip,this will help this vehicle to stop having first crank failures which is vary common on FORDS.
AudioPro111
