How to hook tach sensor wire?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40322
Printed Date: March 27, 2026 at 9:32 PM
Topic: How to hook tach sensor wire?
Posted By: ivanca
Subject: How to hook tach sensor wire?
Date Posted: October 05, 2004 at 12:43 PM
I am not really know how to hook up the tach sensor wire for remote starter.
I read many remote starter's manual. There are 2 ways for detecting the tach as below.
posted_image
posted_image
For example, PONTIAC TRANSPORT 1990-1993
TACH SENSORWHITE at IGNITION COIL MODULE
Which detecting way is better? Connect it drectly or just round 10 loops on it?
I am new installer. Sorry for asking so stupid questions.
Posted By: ivanca
Date Posted: October 05, 2004 at 12:46 PM
Images link can not be displayed here. i have to upload them again here
WAY 1:
posted_image
WAY2:
posted_image
Posted By: mo12v
Date Posted: October 05, 2004 at 3:36 PM
R U using the WRAP around Plug or coil method or can U use a direct TACH connection?
U can also hook it up here:
Tach SignalWHITEIGNITION MODULE OR AT E.C.M./P.C.M. *
* Base Models Are Throttle Body Injected
also
1992 - 1993  3.1L  Passenger Dash Black 32 Pin connector, Position D-4
1992 - 1993  3.1L  Passenger Dash Black 32 Pin connector at PCM, Position C-9
MO
Posted By: Teken
Date Posted: October 05, 2004 at 4:08 PM
I dont think his picture is big enough. Perhaps it could be a little bigger so I can see it. posted_image
Regards
EVIL Teken . . .
Posted By: ivanca
Date Posted: October 05, 2004 at 6:49 PM
I work for a company selling a lot of alarms. So there are many ways to detect the engine starting. But whatever, just give above 4V to that wire on alarm when engine is starting, it will work well. But just not really know which way is the best. For some vehicles, round 5 loops is not working though the manual says it does.
Some alarm's manual says it should connect to engine oil pressure sensor. But it is hard to locate the engine oil pressure sensor wire. Most vehicle's installation wiring sheet only provides the "TACH SENSOR" wire. For this case, mostly, I connect it directly to the tach wire, it works well. Isn't high volt? But the alarm didn't burn. Why? But if I round 10 loops on the tach wire, it wouldn't work. Why?
mo12v] wrote:
/p>
also
