Changing LED Flash Rate?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40775
Printed Date: April 10, 2026 at 5:20 AM
Topic: Changing LED Flash Rate?
Posted By: shesaidshewas18
Subject: Changing LED Flash Rate?
Date Posted: October 12, 2004 at 9:39 PM
I recently bought some blinking LED's and I was wondering if there was a way to change the speed rate of how fast they blink. Any suggestions will be appreciated. TIA
Posted By: Teken
Date Posted: October 12, 2004 at 10:27 PM
The internal value of the capacitor would need to be changed, which affects the flash rate.
The smaller the value, the faster the (on) rate of flash, conversly, the larger the value, will increase the (off) flash rate.
Regards
EVIL Teken . . .
Date Posted: October 12, 2004 at 11:37 PM
Thanks Teken, but is it possible to add an external relay to change the values?
Posted By: Teken
Date Posted: October 13, 2004 at 2:46 PM
No, the internal value of the capacitor within the unit, needs to be changed.
Unfortunately, all the Radio Shack units I have ever seen, do not appear to be user friendly, when it comes to disassembly.
Regards
EVIL Teken . . .
Posted By: tcool
Date Posted: October 13, 2004 at 8:41 PM
One way you could go is to buy a varad LED. They have adjustable blinking speeds. You would hook it up to power and the neg starter kill output of your alarm. You would lose some functionality of the regular alarm LED (assuming your LED lights solid when in valet, blinks rapidly before passive arming or gives you some kind of alarm report upon disarm).
https://www.varad.com/products/products-index.html
bzzzzttttt
