2004 Toyota Sienna Wire Diagram Needed
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40834
Printed Date: April 09, 2026 at 3:52 AM
Topic: 2004 Toyota Sienna Wire Diagram Needed
Posted By: newinstaller
Subject: 2004 Toyota Sienna Wire Diagram Needed
Date Posted: October 13, 2004 at 7:29 PM
Hi,
I am looking for a  2004 Toyota Sienna Wire Diagram.
I am installing a Compustar 2WFMAS Alarm/Starter
Any help would be great
Anyone Got DEI??
Posted By: snguyen
Date Posted: October 13, 2004 at 7:31 PM
Toyota
Sienna
2004-2004
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
BLACK / YELLOW
IGNITION SWITCH HARNESS *
Ignition #1:
Black
Ignition #2:
BLACK / YELLOW
Ignition #3:
Blue/Black (-)
Use Key Sense wire to disarm the OEM factory alarm. **
Accessory:
Pink
Brake Light:
GREEN / WHITE (+)
Above the brake switch
Tach Signal:
BLACK/ Orange
ECM located behind the glovebox
Parking Lights:
GREEN/ Black (-)
Headlight Switch
Headlights:
N/A
OEM Alarm Disarm:
Key Sense Wire
OEM Alarm Arm:
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
*This Vehicle is equipped with Transponder Theft System. Use Universal Alarm Bypass Module part #2x402 where X can be any number. **Use the WHITE/ Black IGN3 wire from the unit to disarm the alarm. The key sense wire will measure a ground while the key is in the ignition switch.
Toyota
Sienna
2004-2004
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
WHITE/ Blue (+)
Ignition Switch Harness
Starter Kill:
BLACK / YELLOW
Ignition +12 Volts:
Black
Dome Lights/Superv:
See Note Below ***
See Note Below***
OEM Horn:
GREEN/ Black (-)
Below the steering column
Power Lock:
Lt. Green (-)
Drivers kick panel
Power Unlock:
Blue (-)
Drivers kick panel
Trunk Release:
Yellow/Red (-)
Fuse Box Below drivers kick panel
Alarm Input Wire:
See Note Below ***
See Note Below***
Notes:
*** The vehicle has individual door triggers. Driver's door RED / Yellow(-),The drivers door and the passengers share the same wire. The left sliding door is gray (-). Right sliding door RED / white. These wires will be located at the BECU module located at the fuse box in the driver's kick panel.
Date Posted: October 13, 2004 at 7:34 PM
is this DEI?
Posted By: snguyen
SIENNA 2004
WIRE COLORSLOCATION
12 VOLTS CONSTANT
WHITE/ RED and WHITE/ BLUE
IGNITION 1BLACK (+)IGNITION SWITCH HARNESS
IGNITION 2
BLACK / YELLOW (+)
ACCESSORY /HEATER BLOWER PINK (+)IGNITION SWITCH HARNESS
STARTERBLACK / YELLOW (+)IGNITION SWITCH HARNESS
PARKING LIGHTS (-)GREEN/ BLACK (-) See NOTE *@ HEADLIGHT SWITCH
DOME LIGHTRED / GREEN (-)@ INTERIOR LIGHT SWITCH ON DASH
POWER DOOR LOCKLIGHT GREEN              See NOTE **IN DRIVERS KICK PANEL, in an 18 Pin Plug (TYPE B)
POWER DOOR UNLOCKBLUE  See NOTE **IN DRIVERS KICK PANEL, in an 18 Pin Plug (TYPE B)
TRUNK RELEASEYELLOW/RED (-) @ BOTTOM LEFT of FUSEBOX 22 Pin Plug
TACH SENSORBLACK/ ORANGE      NOTE ***@ ECM, Connector E4, Pin 5
BRAKE
GREEN / WHITE (+)@ SWITCH ABOVE BRAKE PEDAL
HORN
GREEN/ BLACK (-)@ STEERING COLUMN HARNESS
FACTORY DISARM
disarms with Unlock
FACTORY ANTI-THEFT
TRANSPONDERRequires #791 Bypass Module and Extra Ignition Key
NOTE *     You CANNOT USE any (+) Positive Parking Light circuit on this vehicle, you MUST use the (-) Negative Parking light circuit and this will require an extra Relay Part # 775, to order contact:  DIRECT WHOLESALE at 1-800-659-0764.
NOTE **    These 2 wires will ONLY meter (show a Ground or (-) Negative) when you place a key in the DRIVERS DOOR KEY CYLINDER (outside of drivers door) and rotating from Lock to Unlock. You must use a Double Pulse Unlock programming on this vehicle. For a Single Pulse Unlock you can use the wire in the Passengers kick panel in a 12 Pin Plug, it will meter off of the Passengers key cylinder, the wire is a BLUE / YELLOW (-).
NOTE ***   The ECM is located behind the Glovebox.
Date Posted: October 13, 2004 at 7:37 PM
thanks so much buddy
your the best
