2005 Chevy Tahoe R/S Tip
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=40857
Printed Date: April 09, 2026 at 2:07 AM
Topic: 2005 Chevy Tahoe R/S Tip
Posted By: NismaX
Subject: 2005 Chevy Tahoe R/S Tip
Date Posted: October 14, 2004 at 8:17 AM
Hi,
Just finished an '05 Chevy Tahoe. This baby was loaded to the hilt and even had the factory nav radio in the dash. The problem I encountered was the gauges, radio, and drl would pulse on and off once the vehicle started. Well I decided to power up the brown lead as accessory. That did the trick. In the past this wire was not necessary but, it looks like in some of the new vehicles it is. Another thing strange was the DB-DLM-3 from Omega would not always shut down the RAP system leaving the radio on. I ended up going into the door and to the grey/black door pin wire on the DDLM to shut it down manually. I did make Omega aware of this and they are going to investigate. It seems that now we may have to develop a digital code reader to read the buss systems in these vehicles so we can have a clue of what is going on.
Jon
Traveling Electronics
Posted By: NowYaKnow
Date Posted: October 14, 2004 at 6:00 PM
I have yet to find any logic or pattern behind the brown wire on GM's. You can do 50 of them and the brown wire may need to be fired up 2 or 3 times. Doesn't seem to matter what car, year, etc it is completely random from what I've seen. By the way, I've done an 05 Tahoe w/ nav as well and didn't fire up the brown wire, no problems. I have noticed on the newer GM's the radio still comes on when you don't fire up the brown wire, so I'm not sure what all it's powering nowadays. Anyone else with any info feel free to enlighten me.
Mike
Posted By: sparkie
Date Posted: October 14, 2004 at 8:13 PM
In the newer GM vehicles the brown wire powers up accessories, but not the radio anymore. The Body Control Module senses the ignition turning on and it sends a data message to the radio to tell it to turn on. The radio will turn off when the BCM tells it to. The BCM must see the ignition turned off and a door opened to tell the radio to turn off. Depending on the vehicle and it's options/engine you may or may not have to power up the brown wire. It powers up some critical modules for anti-theft, engine or transmission at times.
Now you know, NowYaKnow.
sparky
Posted By: FairWeather
Date Posted: October 16, 2004 at 1:15 AM
I am about to start an 04 Tahoe. I'm using Trilogix's GMDL-BP combo module. When you powered up the brown accessory wire, did you disconnect the orange accessory? If not, did you tie the brown and orange together into the R/S accessory? Thanks from an installer not familiar with GM vehicles.
Also, thanks for the tip! I'm sure you saved me some time.
You can do it!
Posted By: extreme1
Date Posted: October 16, 2004 at 10:17 AM
you never ever tie two vehicle wires together, the brown acc wire works differently than the orange, the orange only works in the ON position of the IGN switch where as the brown also adds the ACC position to what it does.
To date I've never had to energize the brown acc wire in any GM vehicle for remote start including 2005 Trucks
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Date Posted: October 16, 2004 at 10:22 AM
Extreme1, I agree on using only orange. However, do you think NismaX diode-isolated the connections?
You can do it!
Posted By: NismaX
Date Posted: October 16, 2004 at 7:56 PM
Hi,
No, I didn't use diodes or connect the wires together. I used a relay getting it's power (relay term 30) off the red ign harness lead. It follows the acc lead (term 86). Is hooked to the ground out when running lead from your remote starter (term 85) and finally hooked to the brown lead (term 87). I have never had to hook up a brown lead except in the Cavliers. Just never had the gauges do that to me before. I have done lots of other trucks and I do mean lots! My biggest customer is a Chevy dealer. Ahh things do change from time to time it just keeps us on our toes.
Jon
Date Posted: October 16, 2004 at 8:48 PM
Thanks, NismaX.
I'm tossing up this chart that I used to map my connections. Anyone see any problems before I start soldering?
Compustar 2wss-as2004 Tahoe z71Module: GMDL-BP (trilogix)
HarnessPinWire ColorWire FunctionPol WireColorPolLocation WireColorPol
CN11Red12V Constant+12V ConstantRed+Ignition Harness12V ConstantRed+
2GREEN / WHITEParking Light
3RED / White12V Constant+12V ConstantRED / White+Ignition Harness
4WhiteAccessory (blower motor)+AccessoryOrangeIgnition Harness
5Violet2nd Ignition
6YellowStarter OutputStarterYellow+Ignition Harness
7GREEN/ RedIgnitionIgnitionPink+Ignition Harness
8BlackGroundChassis GroundChassis GroundBlack
CN21GREEN / WHITEParking light output-Parking Lightsgray/black-BCM, brown plug, pin B2
2BlackStatus Out wire (gnd when running)-Gnd When RunningBrown-
3GreenIgnition Output-
4WHITE/ BlackAccessory Output-
5RED / BlackStarter Output-
CN31Light BlueParking Brake-
2Gray/BlackHood Trigger-
3Light Blue/WhiteFoot Brake Shutdown+Brake WireWhiteBrake Pedal Switch
4Violet/BlackTrunk Trigger Input-May require Trunk Pin from Tahoe to Compustar CN3 Pin 4. Module may do it though
5RED / WhiteDoor Trigger Input-Door Trigger OutputPink/White-
6Red Door Trigger Input+
7BROWN / BlackGlow Plug-
8BROWN / WhiteGlow Plug+
9Yellow/BlackTach InputacTachometerWhiteInstrument Cluster, Pin A5
CN41N/A
2Violet/WhiteTrunk Unlock-
3ORANGE / BlackDriver's Door Priority Unlock-
4BlueUnlock Output-Unlock InputBlue-
5Blue/BlackLock Output-Lock InputGreen-
6N/A
Horn TriggerBLACK / YELLOW to Black-BCM, gray plug, pin B9 or ColumnHorn InputOrange-
ODBII (Pin #2)VioletData OutputViolet
Dome Light SupGray/Black+BCM, black plug, pin EDome Light InputPink+
Please forgive me if I have violated forum ethics with this chart. I had no vicious intent. I tried a picture but couldn't keep it under 30 KB.
Any help is appreciated.
You can do it!
