2000 ELANTRA REMOTE/STARTER
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41
Printed Date: April 13, 2026 at 6:30 AM
Topic: 2000 ELANTRA REMOTE/STARTER
Posted By: jasgal
Subject: 2000 ELANTRA REMOTE/STARTER
Date Posted: March 13, 2002 at 8:37 PM
i BOUGHT A REMOTE STARTER AND AN ACTUATOR FOR THE CENTRAL LOCKING SYSTEM.  Is any body familiar w/ these cars.......i posted earlier about the degree of difficulty im getting into.  but can i take the casing from aroung the steering wheel off with ease to get to these wires around the ignition.  i am going to attemp to install this on my 200 elantra this weekend....just want to know what i am getting my self into....thanks for any help...
Posted By: jasgal
Date Posted: March 13, 2002 at 8:39 PM
also......didn't mention...i am installing the who remote starter ...not just the actuator.....and i also want to have the lights flah when the starter activates.....this is an option...where do i ti into the parking light.....is this near the steering column.....?
Posted By: Velocity Motors
Date Posted: March 13, 2002 at 11:00 PM
This is a very straight forward installation. Go here for the wire codes :https://www.bulldogsecurity.com/wires/hyunelan99-01.htm and the parking lights you just have to splice the parking light wire from the remote starter to the GREEN / WHITE wire coming off the driver kick panel or the light switch. test to make sure that this is in fact the wire.
Most of the wires you will find if you remove the panel under the steering column by your knee and once you have all the wires in sight, test to verify that the wire is infact the wire that you wish to splice into ( use solder ) and then test the unit.Good luck and if you need more help with this just post your concerns and we'll be more than happy to help you out.
