1997 Dodge Viper
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41030
Printed Date: April 12, 2026 at 7:33 PM
Topic: 1997 Dodge Viper
Posted By: draasch
Subject: 1997 Dodge Viper
Date Posted: October 16, 2004 at 8:36 PM
a buddy of mine that i work with here at the station has a 1997 Viper.....its one hell of a car....he has the factory alarm in it right now....he wants me to do an install before the big car show in vagas next month...the factory alarm doesnt unlock the doors per say...it allows the door popper to work...anyone ever work on one like this before???????
any ideas would be great!
thanks,
david ------------- Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: extreme1
Date Posted: October 16, 2004 at 9:02 PM
12 VOLTS red + ignition harness
STARTER 1 yellow + ignition harness
IGNITION 1 dk. blue + ignition harness
ACCESSORY 1 orange + ignition harness
POWER LOCK WHITE/ dk. green + drivers door boot
POWER UNLOCK pink/white + drivers door boot This wire will OPEN the drivers door, ORANGE / white(+) in the passenger boot will OPEN the passenger door. Do NOT use ignition control door locks.
FACTORY ALARM ARM yellow/black + alarm module Factory alarm and keyless entry modules located on driver's side of transmission tunnel. Wires available here include: RED / wht (12V+), dk. blue/wht (ign), blk/red (horn -), blk/yel (pk lts +), yel (door trig -), blk/org ('Armed' light). Note that there is a serial data buss between the alarm module and the ignition controller which must remain active for the car to run. You can remove the keyless module (and probably should to prevent RF problems with your alarm) but leave the factory alarm plugged in and interface it with your alarm.
FACTORY ALARM DISARM lt. GREEN/ orange - alarm module Factory alarm and keyless entry modules located on driver's side of transmission tunnel. Wires available here include: RED / wht (12V+), dk. blue/wht (ign), blk/red (horn -), blk/yel (pk lts +), yel (door trig -), blk/org ('Armed' light). Note that there is a serial data buss between the alarm module and the ignition controller which must remain active for the car to run. You can remove the keyless module (and probably should to prevent RF problems with your alarm) but leave the factory alarm plugged in and interface it with your alarm.
PARKLIGHTS POSITIVE BLACK / YELLOW + headlight switch
PARKLIGHTS NEGATIVE -
HEADLIGHT lt. green + headlight switch
BRAKE WHITE/ tan + brake pedal switch
DOOR PIN yellow - headlight switch
TRUNK PIN Running wires to the trunk of this sled is no fun. There is a path through the right rear fender well if you pull the large grommet in upper rear passenger side trunk (stereo harness there already) and drill a hole high in the upper corner of c**kpit on passenger side below the first weld mark. This will bring you out in the fender well above the liner and a thin stiff fish will find its way to the large grommet.
TACH gray/lt. blue behind gauge or pcm
TRUNK RELEASE Unless you want to drill the rivets on the stock latch mechanism and do some welding on the innards, don't sell this option. Also see note on running wires to trunk.
HORN black or - steering column Factory alarm and keyless entry modules located on driver's side of transmission tunnel. Wires available here include: RED / wht (12V+), dk. blue/wht (ign), blk/red (horn -), blk/yel (pk lts +), yel (door trig -), blk/org ('Armed' light). Note that there is a serial data buss between the alarm module and the ignition controller which must remain active for the car to run. You can remove the keyless module (and probably should to prevent RF problems with your alarm) but leave the factory alarm plugged in and interface it with your alarm.
It's an interesting one, that's for sure...
------------- Shaughn Murley
Visions Electronics
Red Deer, Alberta
