04/05 F series truck remote start wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41108
Printed Date: April 10, 2026 at 9:34 PM
Topic: 04/05 F series truck remote start wiring
Posted By: sadkins
Subject: 04/05 F series truck remote start wiring
Date Posted: October 18, 2004 at 7:51 AM
Anyone have 04/05 f series truck remote start wiring info? Please help!
Posted By: mo12v
Date Posted: October 18, 2004 at 8:13 AM
This is what I have: | Constant 12 volts | GREEN/ VIOLET | IGNITION SWITCH HARNESS | | Ignition 12 volts | BLUE/GREEN | IGNITION SWITCH HARNESS | | Starter | RED / BLUE | IGNITION SWITCH HARNESS | | Dome Light | BLACK/ BLUE (+) | DRIVER KICK PANEL | | Trunk Pin Switch | NONE | | | Parking Lamp | BROWN (+) | HEADLIGHT SWITCH | | Power Lock | PINK / YELLOW | DRIVER KICK PANEL | | Power Unlock | PINK/GREEN | DRIVER KICK PANEL |
Negative Pulse Door Lock Circuit | Accessories | | Window Up | D\ TAN/BLU P\ TAN/BLU D\ YEL/BLU P\ RED / BLK AT MAIN SWITCH | | | Window Down | F/ WHT BLK F/ WHT/YEL R/ GRY/ORG R/ YEL/BLK * | | | Ign Key Warn | BLACK/ PINK (-) | 6 PIN CONN RIGHT OF STEERING COLUMN | | Trunk Release | NONE | | | OEM Horn | BLUE (-) | 6 PIN CONN RIGHT OF STEERING COLUMN | | Headlights | RED / YELLOW (+) | HEADLIGHT SWITCH | | OEM Alarm Arm | ARMS WITH LOCK | | | OEM Alarm Disarm | DISARMS WITH UNLOCK | |
* Rear Sliding Window - RED / YELLOW = Close, YELLOW/BLUE = Open At Switch Reversal Rest At Ground Window Circuit | Remote Start | | Tach Signal | NOT RED / LT GREEN | AT ANY COIL (COIL ON PLUG) | | Ignition #2 | BLACK/ LT GREEN | IGNITION SWITCH HARNESS | | Ignition #3 | | | | Accessory | | | | Neutral Safety | NON GROUNDING TYPE | OEM CIRCUIT OPENS STARTER CIRCUIT | | Brake Light | GREEN (+) | AT BRAKE PEDAL SWITCH | | Reverse Light | BLACK/ PINK (+) | 66 PIN CONN IN DRIVER KICK PANEL | | Rear Window Defrost | BLUE/ORANGE (-) | REAR DEFROST SWITCH |
Immobilizer Bypass Circuit Diagram. Data Buss Bypass Module ------------- MO
Posted By: sadkins
Date Posted: October 18, 2004 at 9:51 AM
Thankyou
Posted By: NowYaKnow
Date Posted: October 18, 2004 at 5:50 PM
The info above is for the 2004+ F150. Also the BLACK/ light green should be an accessory wire, not an ignition wire. If you doing a F250 or F350, the information above won't help you. Good luck,
Mike
Posted By: Teken
Date Posted: October 18, 2004 at 6:48 PM
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES LIGHT DUTY / 2004 / Remote Start
12volts lt. GREEN/ purple (20A) + ignition harness
Starter RED / lt. blue + ignition harness
Second Starter N/A
Ignition dk. blue/lt. green + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ lt. green + ignition harness
Second Accessory N/A
Keysense BLACK/ pink + ignition harness
Power Lock pink / YELLOW - DKP or BCM, green plug, pin 9
Notes: The BCM (Body Control Module) is on the driver side rear cabin wall.
Power Unlock pink/lt. green - DKP or BCM, green plug, pin 1
Lock Motor pink/black 5wi DKP or BCM, blue plug, pin 2
Unlock Motor RED / orange 5wi DKP or BCM, blue plug, pin 5
Parking Lights+ brown + switch or BCM, blue plug, pin 6
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org (R) + steering column
Turn Signal(R) wht/lt blu (F), org/lt blu (R) + steering column
Reverse Light BLACK/ pink + DKP, gray plug, pin 13
Door Trigger BLACK/ yel (L), BLACK/ pink (R) - DKP, gray plug, pins 22, 23
Notes: The wiring above is for vehicles without keyless entry. Vehicles with keyless entry, the door trigger wires are found at the BCM, green plug. The LF door trigger is BLACK / YELLOW in pin 4. The RF door trigger is BLACK/ pink in pin 5. The LR door trigger is BLACK/ lt. blue in pin 12. The RR door trigger is BLACK/ white in pin 13. Use all wires and diode isolate each.
Dome Supervision BLACK/ lt. blue + DKP, gray plug, pin 6
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer NOT RED / lt. green or red ac any ignition coil or fuel injector
Wait to start N/A
Brake Wire lt. green + brake pedal switch
Parking Brake lt. GREEN/ red - parking brake switch
Horn Trigger dk. blue - column or BCM, blue plug, pin 12
Memory Seat 1 BROWN / lt. green - memory switch on seat
Memory Seat 2 BLACK/ orange - memory switch on seat
Memory Seat 3 N/A -
Immobilizer Bypass Module: Required: Yes Type: SecuriLock Part #: 556S, 556U, or 555U
Notes: N/A
Posted By: Teken
Date Posted: October 18, 2004 at 6:50 PM
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES SUPER DUTY / 2004 / Remote Start
12volts yellow & lt. GREEN/ purple + ignition harness
Starter green + ignition harness
Second Starter N/A
Ignition RED / lt. green or WHITE/ yellow + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray / YELLOW & RED / black + ignition harness
Second Accessory blue/lt. green + ignition harness
Keysense
Power Lock see notes
Notes: Without keyless entry use pink / YELLOW for lock and pink/lt. green for unlock. They are 5 wire reverse polarity mastered from the driver switch and found in either kick panel. With keyless entry use WHITE/ red for lock and BLACK/ white for unlock. They are negative trigger and found at the VSM.
On the vehicles with keyless entry the GEM shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1094.
Power Unlock see power lock notes
Lock Motor pink/black 5wi VSM
Notes: The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Unlock Motor RED / orange 5wi VSM
Parking Lights+ brown + headlight switch
Parking Lights- N/A
Hazards same as turn signals
Reverse Light BLACK/ pink + fuse box
Door Trigger BLACK/ lt. blue + passenger kick panel
Dome Supervision use door trigger
Trunk/Hatch Pin N/A
Hood Pin N/A
Factory Alarm Arm
Disarm No Unlock
Tachometer NOT RED / lt. green ac any ignition coil
Notes: On diesel vehicles the tach wire is GREEN / WHITE in a 5 wire harness held up with white tape behind the parking brake release.
Wait to start see DirectFax document 1091
Horn Trigger blue - steering column or VSM
Memory Seat 1 BROWN / lt. green - memory mod under dr seat
Memory Seat 2 BLACK/ orange - memory mod under dr seat
Memory Seat 3 N/A -
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
Date Posted: October 18, 2004 at 7:50 PM
Or I guess I could've just posted the info ;) Anyway since he posted it here's some notes on the Super Duty..
"Ignition RED / lt. green or WHITE/ yellow + ignition harness"
If it's an 04 gas engine ignition is RED / green, if it's an 04 diesel engine the ignition is WHITE/ yellow. If it's an 05 gas OR diesel, ignition is RED / green.
"Accessory gray / YELLOW & RED / black + ignition harness
Second Accessory blue/lt. green + ignition harness"
Regardless you should power up gray / YELLOW as acc 1 and RED / black as acc 2. The blue/green shouldn't be necessary.
"Tachometer NOT RED / lt. green ac any ignition coil
Notes: On diesel vehicles the tach wire is GREEN / WHITE in a 5 wire harness held up with white tape behind the parking brake release."
The GREEN / WHITE tach wire is a lower signal on the late 04/05 trucks. If your module won't seem to program the tach, you'll either need a tach booster module or use an alternative source for a tach signal. On the 6.0 diesel, alternative tach source is the crankshaft sensor @ the underhood PCM. Remove the battery terminals and plastic cover from the battery on the DRIVER side of the engine bay to reveal the PCM next to the battery on the fenderwell. There will be 3 plugs at the pcm you want the GRAY wire in the center plug. I believe it is the only plain gray wire in the plug (watch out for gray/blacks) and I believe it is taped in a harness of its own (within the main harness) with a black wire, orange wire, and red wire. The wire will read about 1 - 1.5 volts ac at idle, and rise to 2+ volts ac when revving the engine. Good luck,
Mike
