wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41129
Printed Date: April 10, 2026 at 8:22 AM
Topic: wiring diagram
Posted By: khal2baba
Subject: wiring diagram
Date Posted: October 18, 2004 at 1:12 PM
Hi Iam trying to install this compustar  cm3000 to my ford escape 2002 need
complit wiring diagram anyone can help me out please
   thanks :errr:
Posted By: snguyen
Date Posted: October 18, 2004 at 1:16 PM
Ford
Escape
2001-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
TAN/LT. BLUE
IGNITION SWITCH HARNESS *
Ignition  #1:
LT. GREEN/ PURPLE
Ignition #2:
Brown or Gry/Yel
Ignition  #3:
N/A
Accessory:
BLACK/ LT. GREEN
Brake  Light:
LT. GREEN (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
Parking Lights:
BROWN (+)
DRIVER'S KICK PANEL
Headlights:
RED / WHITE (-)
SWITCH, STEERING COLUMN OR # PIN PLUG AT GEM **
OEM Alarm  Disarm:
BLUE/LT. GREEN (-)
IN # PIN PLUG AT GEM MODULE **
OEM Alarm  Arm:
LT. GREEN/ BLACK (-)
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
Notes:
 * This vehicle is equipped with a transponder immobilizer system. See Installation Note #144 Bypassing Transponder Theft Systems. ** GEM Module Is Located On The Floor Behind The Center Console To The Right Of The Gas Pedal. Remove The Black Plastic Panel And Remove The Carpeting Covering It. ***Ign2 Brown or Gry / YELLOW not present in all vehicles.
Ford
Escape
2001-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED / LT. BLUE
Starter  Kill:
TAN/LT. BLUE
Ignition  +12 Volts:
LT. GREEN/ PURPLE
Dome  Lights/Superv:
PURPLE / LT. GREEN (-)
OEM Horn:
YELLOW/LT. GREEN (-)
STEERING COLUMN HARNESS
Power  Lock:
PINK/WHITE
DRIVER'S KICK OR # PIN PLUG AT GEM MODULE ***
Power  Unlock:
PINK/WHITE
Trunk  Release:
N/A
Alarm  Input Wire:
Notes:
*** Single Wire System, A Negative Pulse Through A 1,000 Ohm Resistor Locks The Doors. A Negative Pulse Unlocks The Doors. Diode Isolate Each Wire With The Band Of The Diodes Facing The Alarm/Remote Start Module. See Note #211
