2000 toyota Sienna wire locations?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=4114
Printed Date: May 16, 2026 at 5:42 PM
Topic: 2000 toyota Sienna wire locations?
Posted By: Dohctor
Subject: 2000 toyota Sienna wire locations?
Date Posted: October 01, 2002 at 9:59 PM
Just wanted to know if anyone new were the power door lock module and wiring is to hook up a keyless entry system to a 2000 Toyota Senna? Thanks in advance.
Posted By: djfearny2
Date Posted: October 02, 2002 at 12:11 AM
tehy should be in driver side kick panel wire colors are
lock- blue/white
unlock -blue / YELLOW
this is a negative door lock system.
Jon
Installer/Help Technician
---coral springs florida---
Posted By: Dohctor
Date Posted: October 02, 2002 at 4:12 AM
Thanks alot for your help!
Posted By: Dohctor
Date Posted: October 02, 2002 at 4:19 AM
You dont happen to have a complete alarm hook up and locations chart on that vehicle do you? Thanks.
Posted By: Velocity Motors
Date Posted: October 02, 2002 at 5:18 AM
|              12V|wht/red & wht/blue  |+  |ignition harness            |
|          STARTER|red                 |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ red           |+  |ignition harness            |
|        ACCESSORY|blue                |+  |not required for r-start    |
|       POWER LOCK|blue/white          |-  |passenger kick panel  *1    |
|     POWER UNLOCK|blue / YELLOW         |-  |passenger kick panel  *1    |
|       LOCK MOTOR|blue/red            |   |integration relay *8        |
|     UNLOCK MOTOR|blue/black          |   |integration relay *8        |
|    DISARM DEFEAT|blue/red            |   |integration relay *8        |
| PARKING LIGHTS +|green               |   |bottom of fuse box          |
| PARKING LIGHTS -|GREEN/ orange        |   |combination switch harness  |
|       HEADLIGHTS|RED / green           |-  |combination switch harness  |
|     DOOR TRIGGER|RED / white           |-  |top right side of fuse box  |
| DOME SUPERVISION|RED / black           |-  |right side of fuse box      |
|  TRUNK/HATCH PIN|GREEN/ black         |-  |top right side of fuse box  |
|         HOOD PIN|black               |-  |at light or theft ECU *2    |
|TRNK/HTCH RELEASE|GREEN/ YELLOW *9     |-  |switch on dash below radio  |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
|       TACHOMETER|yellow, grn, or blue|   |*3                          |
|      SPEED SENSE|violet / YELLOW       |   |at ECM below glove box      |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake switch or fuse box    |
|     HORN TRIGGER|GREEN/ black         |-  |steering column             |
|           WIPERS|blue/blk, blue/org  |+  |wiper switch *4             |
|  LF WINDOW UP/DN|green   -    red    |A  |in drivers door at switch   |
|  RF WINDOW UP/DN|grn/wht  -  RED / blue|A  |in drivers door at switch   |
|  LR WINDOW UP/DN|red   -   yellow  *5|A  |must go to motor (rear vent)|
|  RR WINDOW UP/DN|red   -   yellow  *5|A  |must go to motor (rear vent)|
| SUN RF OPN/CLOSE|red   -   green     |A  |at motor or sunroof relay *6|
|   SUN ROOF LIMIT|RED / blue or grn/wht |-  |at sunroof relay  *6        |
|        RADIO 12V|blue / YELLOW         |+  |stereo or amp *7            |
|     RADIO GROUND|brown               |-  |stereo or amp *7            |
|     RADIO SWITCH|gray                |+  |stereo or amp *7            |
| RADIO ILLUMINATE|WHITE/ green         |-  |dimmer switch               |
|       LF SPEAKER|pink   -   violet   |non|stereo or amp *7            |
|       RF SPEAKER|lt. green  -   blue |non|stereo or amp *7            |
|       LR SPEAKER|black  -   yellow   |non|stereo or amp *7            |
|       RR SPEAKER|red   -   white     |non|stereo or amp *7            |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start.   *1  they will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door itself.  *2  door lock ECU and theft ECU are in the center console.  *3  located at one of the coils on top of the valve cover.  *4  rear wiper pink/black(-) at wiper switch  *5 rear open & close motors are common through the switch  *6  sunroof relay located front center under headliner.  *7  stereo amplifier in center console below doorlock and theft ECU.  *8  the integration relay is at the bottom of the fusebox.  *9  This is for the power sliding side door.
Posted By: Dohctor
Date Posted: October 02, 2002 at 10:20 PM
Thanks alot Jeff you rule!
Date Posted: October 03, 2002 at 8:36 PM
No problemo... good luck !
