why does this alarm keep going off?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41240
Printed Date: March 18, 2026 at 10:02 PM
Topic: why does this alarm keep going off?
Posted By: Blackiewrx
Subject: why does this alarm keep going off?
Date Posted: October 19, 2004 at 4:23 PM
Its a prestige basic alarm called aps-25 it know has a piggy back remote start module added to it. everything works fine but the alarm will go off everytime its remote started with the alarm armed. Ive relayed the ignition wire so the the alarm dosent see the ignition come on with remote start and ive also disconnected the shock sensor and the darn thing still goes off as soon as the engine cranks, What could be cause this??? Thanks in advance.
------------- 03 wrx stage 4
Posted By: auex
Date Posted: October 19, 2004 at 4:45 PM
It could have voltage sensing or it could turn the dome lights on, or change state long enough while cranking to make the alarm think the doors opened. Completely disconnect the ign wire on the alarm and see if it still does this.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: October 19, 2004 at 5:28 PM
I checked the alarm features and the current sensing is turned off from the factory so i dont think that is it, i will try disconecting the ignition wire all together and see what happens. thanks alot.
Posted By: Teken
Date Posted: October 19, 2004 at 6:11 PM
Check the LED status indicator first. This will narrow down the problem for you. The alarm will blink so many times, check with your user manual and decypher what zone is being tripped.
Most, but not all alarm systems have a sensor defeat / bypass upon RS. Does your unit have this? Is it hooked up?
As Auex suggested, see if there is a voltage feed-back coming to the system during the RS.
Regards
EVIL Teken . . .
