2004 Chev SS alarm/remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41311
Printed Date: March 17, 2026 at 4:28 AM
Topic: 2004 Chev SS alarm/remote start
Posted By: jkyliej
Subject: 2004 Chev SS alarm/remote start
Date Posted: October 20, 2004 at 4:13 PM
I am going to install a remote start/alarm on a 04 chev SS pick up.  This is an extended cab truck not the retro coupe.  It has a 6.0 gas engine with all option. Does anyone have a wiring color chart?
Thank you.
JKJ
Posted By: mo12v
Date Posted: October 20, 2004 at 4:28 PM
This is what I have:
Can Use:  OMEGA # DB-PASS23 for DATABuss Pass2
OR
OMEGA # DB-GMDL-BP for both Door locks & PASS 2
Constant 12 voltsRED OR RED / WHITEIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightDR (-) GY/BK,PAS (-)BLK/WHT AT BCM (BLUE 24 PIN CONN) *
Trunk Pin Switch
Parking LampGRAY/BLACK (-)HEADLIGHT SWITCH
Power LockGRAYIN EACH DOOR ** #
Power UnlockTANDUE TO MULTIPLEXING (BASE MODEL ***)
*Rear Doors:Driver-L BLUE (-), Pass-L GREEN (-) At BCM (VIOLET 24 Pin Conn); Diode Isolate Door Triggers With Stripe (Cathode) Towards OEM Wire ** Door Lock Module Available Call For Details *** Base Model Is Negative Pulse. Lock-L BLUE, Unlock-WHITE; At BCM Negative Pulse Door Lock Circuit Diagram
# Reversal Rest At Nothing Door Lock Circuit
USE DATABuss
Accessories
Window UpD\ BLUE P\ BLUE D\ BLUE P\BLUE @ Each Switch Due to Data Link
Window DownF/ BROWN F/ BROWN R/ BROWN R/BROWN
Ign Key WarnLIGHT GREEN (-)IGNITION SWITCH HARNESS
Trunk Release
OEM HornBLACK (-)STEERING COLUMN HARNESS
HeadlightsWHITE (-)AT HEAD LIGHT SWITCH
OEM Alarm Arm
OEM Alarm DisarmLT GREEN (-)AT DOOR MODULE INSIDE DRIVERS DOOR
 Reversal Rest At Ground Type Window Circuit
OEM Hood Pin Wire Is PINK/BLACK @ Switch On Top Of Radiator Support
Remote Start
Tach SignalWHITEAT PCM *
Ignition #2WHITEIGNITION SWITCH HARNESS
Ignition #3ORANGEIGNITION SWITCH HARNESS
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyWHITE (-)PCM CONN C3 PIN #13 *
Brake LightWHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightLIGHT GREEN (+)EITHER TAIL LT ASSY OR TRAILER CONN
Rear Window Defrost
*PCM Located On The Drivers Side Of The Motor. Tach Wire Is In The BLUE Conn (C1) Closest To The Firewall,Pin #49. Also Found Back Of Cluster in 24 pin GREY Conn Pin # A12
G.M. Passlock II Bypass  (Use The YELLOW And BLACK Wires)
MO
