1997 Mercedes E320. Can remote arm/disarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41397
Printed Date: April 30, 2026 at 12:18 AM
Topic: 1997 Mercedes E320. Can remote arm/disarm
Posted By: Steve 90TTZ
Subject: 1997 Mercedes E320. Can remote arm/disarm
Date Posted: October 22, 2004 at 1:54 AM
I have a 1997 Mercedes E320 that I would like to put a remote starter in but was wondering if it could be setup to arm/disarm the factory alarm. It is the older style mechanical key.
TIA,
Steve
Posted By: mo12v
Date Posted: October 22, 2004 at 9:11 AM
Should be able to if your car has Factory Alarm and the RS has the ability.
Here is what I have:
Constant 12 voltsRED & REDIGNITION SWITCH HARNESS *
Ignition 12 voltsPINK/GREENIGNITION SWITCH HARNESS *
StarterPURPLEIGNITION SWITCH HARNESS *
Dome LightBROWN / GRAY (-)DRIVER KICK PANEL
Trunk Pin SwitchBROWN / YELLOW (-)AT TRUNK LIGHT OR OEM ALARM **
Parking LampGRAY/WHITE & GRAY (+)AT LIGHT SWITCH OR FUSE BLOCK
Power LockBLUE/GREENDRIVER KICK PANEL OR
Power UnlockBLACK/ BROWNAT REMOTE CONTROL UNIT.
Negitive Pulse Door Lock Circuit . * Remove Instrument Cluster (Pry From Both Sides) To Access Ignition Switch. ** OEM Alarm Control Unit In Trunk (On Pass. Side). ***Remote Control Unit Located Behind Right Side Of Dash.
Accessories
Window UpD\ BLK P\ BLK/WHT D\ BLK/VIO P\ BLK/VIO/WHT
* SEE NOTES
Window DownF/ GRN F/ GRN/WHT R/ GRN/VIO R/ GRN/VIO/WHT
Ign Key WarnRED / GREEN (+)IGNITION SWITCH HARNESS
Trunk ReleaseN/A
OEM HornBLACK (-)STEERING COLUMN HARNESS
HeadlightsWHITE/ YELLOW (+)AT LIGHT SWITCH
OEM Alarm ArmYELLOW/BLUE (-)DRIVER KICK PANEL OR OEM ALARM **
OEM Alarm DisarmGREEN/ YELLOW (-)DRIVER KICK PANEL OR OEM ALARM **
*  Reversal Rest At Positive. Location: At Control Module Beneath Rear Seat (Driver Side). ** OEM Alarm In Trunk (Pass. Side). BLUE Unlock Wire Also Disarms OEM Alarm
Remote Start
Tach SignalGREEN/ YELLOWAT DATA LINK CONNECTOR *
Ignition #2PINK/GREENIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryPINK/BLUEIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightBLACK/ RED / WHITE (+)AT SWITCH ON BRAKE PEDAL BRACKET
Reverse LightGRAY / YELLOW (+)AT FUSE/RELAY BLOCK
Rear Window DefrostBLACK (+)AT SWITCH
* Tach Wire Also Found At Instrument Cluster. NOTE: E-420 And E500 Tach Wire GREEN / WHITE.
MO
Date Posted: October 23, 2004 at 6:46 AM
Thanks. Is this for a 1997 E320?
Date Posted: October 28, 2004 at 12:46 AM
I had a Hornet 554t two way with starter and alarm installed today. One problem that we are having is the door unlocks when the car starts and cannot be locked with the remote. The only way to lock it is to use the switch in the centre of the dash. Then you can't unlock it with the factory remote or alarm remote.
Also, can a regular metal key be setup to start the car or do I need to use a factory switchblade key? The only way I can start it without using the factory switchblade key is to use the remote starter to start the car and then use a key in the ignition to keep it running. I would prefer to only carry one remote.
Also how did you mount the switchblade key in the 555u box.
Sorry for all the questions and thanks for all the help,
Steve
Posted By: Velocity Motors
Date Posted: October 28, 2004 at 1:34 AM
As far as the door locks go, what wires did you use and did you bypass the OEM security disarm wire with the unlock wire or with the designated disarm wire from the Hornet ? For the bypass module, if you can't fit the whole switch blade into the container, then try taking the entire circuit board out of the module and slip the switchblade into the loop. You will now need to wrap the circuit board with enough electrical tape to ensure that it is well protected from a possible short. Another way is to make your own bypass module and wrap 20 -22 gauge wire around the switchblade. Use this diagram to help you: https://www.velocitymotorsport.com/images/install_notes/116.jpg
