compustar sensing
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41459
Printed Date: May 01, 2026 at 9:59 PM
Topic: compustar sensing
Posted By: billthe
Subject: compustar sensing
Date Posted: October 22, 2004 at 10:44 PM
Is there anybody know why Compustar using different sensing (tach/alternator) for manual/auto tx . car . Most of the wiring diagram only have the tach sensing. It difficult to find and locate alternator sensing wire. I am looking for the wire location without go to the engine compartment,pls help!
for Mazda mpv 97
billthe
Posted By: billthe
Date Posted: October 31, 2004 at 7:43 PM
The Answer is you can use tach or alt sensing. The manual was misleading. thanks
Posted By: SEXIFIED
Date Posted: October 31, 2004 at 7:54 PM
go tot he odd colour on any one of the injectors.
they all work just the same, but most of us try to use #1 cylinder.
Posted By: proinstall
Date Posted: November 01, 2004 at 8:08 AM
Alt sensing works EVERYTIME no problem.. I use that when possible on the compustars.. but even the tach is still much much much better than the voltage sensing on some other brands..
If the tach is easy to get to just go for that, it will work just fine.
