has anyone ever dealt with command start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41549
Printed Date: April 27, 2026 at 4:29 AM
Topic: has anyone ever dealt with command start
Posted By: SEXIFIED
Subject: has anyone ever dealt with command start
Date Posted: October 24, 2004 at 10:04 AM
have you delt with the brains burning up the park light trace on the board and/or the start wire trace?
Posted By: Velocity Motors
Date Posted: October 24, 2004 at 10:16 AM
I've had a few in the past, but then I installed a fuse on the parking light wire ( PURPLE ). What model number are you haveing troubles with ? I have never liked the CS units personally. They have had many ups and downs with their products as far as quality and reliability.
Posted By: sparkie
Date Posted: October 25, 2004 at 10:00 AM
There is a jumper on the inside of the module to swtich from negative to positive parking lights. The earlier models used a poor jumper that caused this to occur if used in the positive position. Use a small female spade for a jumper. The newer models use an insualted one similar to what is used for many negative speaker terminals.
sparky
Posted By: kgerry
Date Posted: October 25, 2004 at 5:41 PM
i can't count how many recitifiers diodes i replaced in the old 2400 series...... thats one product i would never sell again......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Date Posted: October 25, 2004 at 6:58 PM
You tell 'em Kev !! I can't agree with you more. Wish Staub would just ditch their product already !
Posted By: extreme1
Date Posted: October 25, 2004 at 10:06 PM
Well considering command start went bankrupt years back and the name was bought by automobility.
I've had CS2400/2500's latch the starter relay and burn up starters and batteries.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: gus1
Date Posted: October 26, 2004 at 11:56 AM
Awwwww.... c'mon... they weren't that bad. You always knew when a 2400/2500 was on its way out by how often it would go into tach lockout hee hee!. Seriously though, the 290, 270, 260 were quite solid, even the early 300's weren't bad. They were simple, they worked. The later 300 series were when things started to go really bad (starting by them selves with no way to shut them off... remotes that would just up an start transmitting full bore out of the blue, timer modes that didn't exist etc. etc.)
I even remember the 3000 series... those MOSFET curses with the book sized brain......
Gus
Posted By: kgerry
Date Posted: October 26, 2004 at 12:29 PM
oh come on... who among us wants to go back to wire tying thermistors to the rad hose??  ha ha
it was my experiences with CS that steered me into becoming a DEI dealer and i couldnt imagine going back......
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
