Clifford Alarm Install !!!#%$
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=4157
Printed Date: March 30, 2026 at 11:53 PM
Topic: Clifford Alarm Install !!!#%$
Posted By: sqwert
Subject: Clifford Alarm Install !!!#%$
Date Posted: October 03, 2002 at 1:03 PM
i'm presently wiring a clifford XL500 in a 84 chevy g20 van.  my first time and it seems pretty easy but i'm unsure of a couple things:
  -- alarm's brown wire (for neg park lites)  connects to brown wire near firewall that i've followed to each prk lite.  does it really matter where along it's path i tap into it??
 --- the manual says to run power(red) and black wires straight to battery,  can't i just hook'em up to available spots in the fuse box instead or does it really gotta travel to the battery and WHY??
thanx
JJ Sqwert
Posted By: djfearny2
Date Posted: October 03, 2002 at 5:42 PM
no everything you need is under the dash and in the drivers side kick panel. what you will have to do is connect the brown lightflash wire to a relay  using this settup
pin 85 negative wire from alarm
pin 86and pin 87 fused 10amp fused constant 12 volts.
pin 30 to the possitive light flash wire below is the wire you should be lookign for and where .
Constant 12V+Red Ignition Switch Harness
StarterPurple Ignition Switch Harness
IgnitionPink Ignition Switch Harness
AccessoryOrange Ignition Switch Harness
TachWhite Coil
Brake SwitchWhite Brake Switch
Trunk Pinn/a Same as Dome Light
Parking LightsBrown Light Switch
Hood Pinn/a
Factory Disarmn/a
Door TriggerWhite (-) Driver's Kick Panel
Door LockLight Blue Driver's Kick Panel
Door UnlockBlack or BLACK/ White Positive Trigger
Horn WireBlack (-) Steering Column
Cruise Information  Stereo Information Log Out
Jon
Installer/Help Technician
---coral springs florida---
