resistor ?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41961
Printed Date: April 18, 2026 at 1:53 PM
Topic: resistor ?
Posted By: MJAYCO
Subject: resistor ?
Date Posted: October 31, 2004 at 2:36 AM
I'm trying to hook up my remote start to my parking lights the instructions say to use a 1400 ohm resistor between a relay and the light wire.All I could find is a 1K and 470 ohm resistors if I put them in line will this work? Its on a 2004 Dodge ram. Thanks for any help, Mike
Posted By: SEXIFIED
Date Posted: October 31, 2004 at 8:47 AM
that should work, put them in series and you should get what you need.
Posted By: raydawg357
Date Posted: November 02, 2004 at 7:42 AM
You can also catch the parking light wire under the hood behind the fuse box.
Do it right the first time
Posted By: misterjimbo
Date Posted: November 02, 2004 at 8:37 AM
If you get them at the fus box they are 12v and do not require the relay or resistors
