2004 toyota camry remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41974
Printed Date: April 18, 2026 at 9:32 AM
Topic: 2004 toyota camry remote start
Posted By: hdroadking
Subject: 2004 toyota camry remote start
Date Posted: October 31, 2004 at 12:52 PM
have bulldog remote start hooked up with an auidiovox alarm, car starts then shuts off in five seconds,book says need a bypass module,got one but wires dont match and i do not have an encrypted key....... im baffled please help
road kings rule
Posted By: audiopro111
Date Posted: October 31, 2004 at 1:45 PM
if your car is an ex model then this means u have a transponder type key so this means u may need to use your valet key to place inside a bypass box if not there may be a few things wrong on your install for example:  did u program your tach wire,did u power up all of the ignitions this vehicle requires 2 ign. wires,did you power up the thin yellow/blk this is your second starter wire that must be powered up during crank,if you installed a hood pin make sure that when vehicle cranks it's not grounding out,make sure if car has factory alarm u are sending a negative pulse to blue, blue/blk,green,etc key sense wire at 2 pin plug at ign.cylinder   the key sense wire will show u voltage when key is out of ign. and ground when key is in..take these steps into consideration and post your results.
AudioPro111
Posted By: mo12v
Date Posted: October 31, 2004 at 2:07 PM
Constant 12 voltsWHITE/ REDIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ REDIGNITION SWITCH HARNESS
StarterBLACK / YELLOW AND BLACK/ WHITEAT IGNITION SWITCH HARNESS *
Dome LightRED / BLACK (-)22 PIN CONN,TOP LEFT REAR OF ECU **
Trunk Pin SwitchGREEN (-)PIN 2 OF 12 PIN CONN.IN DR. KICK
Parking LampGREEN (+)PIN 19 OF 20 PIN CONN.BOTTOM FUSE BOX
Power LockBLUE / YELLOW12 PIN BLU CONN DRIVER KICK
Power UnlockBLUE20 PIN WHT CONN DRIVER KICK ***
* There Are Two BLACK / YELLOW Wires Please Check. ** ECU Located At Back Of Driver Side Fuse/Junction Block *** First Pulse Unlocks Driver 2nd Pulse Unlocks The Rest. Unlock Detection Wire Is GREEN
Negative Pulse Door Lock Circuit
Accessories
Window UpD\ GREEN P\ GRN/WHT D\ GRN/YEL P\ GRN/BLK @ MAIN SWITCH
Window DownF/ RED F/ RED / BLU R/ RED / YEL R/ RED / BLK
Ign Key WarnL BLUE (-)2 PIN CONN BEHIND IGN HARN CONN *
Trunk ReleaseWHITE/ BLUE (+)AT 12 PIN WHT CONN DR KICK
OEM HornGREEN/ BLACK (-)24 PIN CONN,LOW FRT OF JUNC/FUSE BOX
HeadlightsRED / YELLOW (-)AT HEADLIGHT SWITCH
OEM Alarm ArmWORKS WITH DOOR LOCKS
OEM Alarm DisarmWORKS WITH DOOR LOCKS
*NEG Pulse Before IGN (Remote Start) Will Disarm OEM Alarm
Reversal Rest At Ground Power Window Circuit
Reversal Rest At Ground Trunk Release
OEM Horn Wire: WHITE At Theft Deterrent E.C.U. OEM Alarm Hood Trigger:BLACK At Theft Deterrent E.C.U.
Remote Start
Tach SignalBLACK/ ORANGEGREY 22 PIN CONN RT OF STEER COLUMN
Ignition #2BLACK / YELLOWIGNITION SWITCH HARNESS *
Ignition #3
AccessoryBLUE/REDIGNITION SWITCH HARNESS
Neutral SafetyNON GROUNDING TYPE
Brake LightGREEN / WHITE20 PIN CONN,LOW LFT OF FUSE/JUNC BOX
Reverse LightRED / BLACK (+)20 PIN CONN,LOW LFT OF FUSE/JUNC BOX
Rear Window DefrostYELLOW /GREEN (-)8 PIN CONN,FRT RT OF FUSE/JUNC BOX
 Immobilizer Bypass (Some Vehicles Reported W/O)
Requires 3rd Key (PASS-4)
* Cold Start Wire BLACK / YELLOW There Are Two BLACK / YELLOW Wires One Tests Like A Starter Wire The Other Like A Ignition
MO
Date Posted: October 31, 2004 at 2:30 PM
not a transponder type car am checking other suggestions,,,,thank you
road kings rule
