delta pro2k combo
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=4217
Printed Date: April 01, 2026 at 6:55 AM
Topic: delta pro2k combo
Posted By: chevy
Subject: delta pro2k combo
Date Posted: October 06, 2002 at 2:44 AM
someone pls help....1st timer...
vehicle- 01 chevy silverado...i'm installing a delta pro2k combo alarm w/ remote starter...my truck has a passlock 2 immobilizer system...how do i connect my unit to a DEI 555L...the pro 2k installation guide state that the orange (armed & start output) connect to a 30 amp relay for starter kill output. Does the 555L handle the relay or do i need both?...Sorry if q is unclear, but i'm confusedposted_image...also, can i connect to my factory alarm disarm thru the BCM...if yes, whaat is the pin location
thx, any and all help is greatly apprecaited!!!!!
willie
Posted By: Velocity Motors
Date Posted: October 06, 2002 at 9:11 AM
  • FCTRY ALRM DISARM              lt.green            | -  |drivers kick
  • Also found in the purple plug of the BCM
  • The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle.
  • You need to hook up the STARTER DISABLE wire ( ORANGE ) on the Pro2K to a 30/40 amp relay like this diagram:https://www.the12volt.com/relays/page2.asp#sk1
  • Make sure that when you attach the starter wire for the Pro2K it's attached on the motor side of the relay, not the keyside (  ignition side ) of the relay
Posted By: chevy
Date Posted: October 06, 2002 at 4:15 PM
thx jeff,
info helped...new problems,
-vehicle starts w hood open or close.....do i need to install a trigger pin?.........
willie-  help apprecaited..............
Date Posted: October 06, 2002 at 4:57 PM
Yes, you need to install a hood pin switch or a mercury switch . Connect this to the HOOD / TRUNK wire on the Delta 2000.
