1998 Nissan Sentra Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42191
Printed Date: April 06, 2026 at 1:40 AM
Topic: 1998 Nissan Sentra Remote Start
Posted By: tj94accord
Subject: 1998 Nissan Sentra Remote Start
Date Posted: November 03, 2004 at 4:40 PM
Hi, my sister ordered a remote start for her car, 98 Sentra, and I'm gonna put it in for her. I looked up the wire colors on here, and noticed that it only had one starter wire. Is that right? I used to work in a shop a few years ago, and I thought that most Nissans had two starter wires? Just wondering if that is right, I guess I could just test the wires to find out... lol.
Oh and a side question, when hooking up to the horn, should you use a relay, even if it is a negative output from the remote starter, and a negative trigger horn?
tim
Posted By: kgerry
Date Posted: November 03, 2004 at 4:49 PM
always use a relay.... the negative out is very low current.......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Date Posted: November 03, 2004 at 5:01 PM
Thats what I thought. Do you know if the Sentra has a second starter wire?
Thanks!
tim
Posted By: kgerry
Date Posted: November 03, 2004 at 5:04 PM
yep, BLACK/ green with the ign wires... keep an eye out cause sometimes they change color after the connector on the column....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
