Wire diag needed 94 4runner
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42197
Printed Date: April 06, 2026 at 5:02 AM
Topic: Wire diag needed 94 4runner
Posted By: minhpham
Subject: Wire diag needed 94 4runner
Date Posted: November 03, 2004 at 6:55 PM
I am installing a Clifford Matrix RSX3.5 into my 1994 4runner. Anyone have the wiring diagram for this SUV? How difficult is this install? Any installers in the San Jose Bay Area wanna give me a hand or advice? ;>
Posted By: mo12v
Date Posted: November 04, 2004 at 2:13 PM
Constant 12 voltsWHITE/ RED AND WHITEIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ REDIGNITION SWITCH HARNESS
StarterBLACKIGNITION SWITCH HARNESS
Dome LightBLACK (-)AT WHITE 3 PIN CONNECTOR@FUSEBOX
Trunk Pin SwitchGREEN / WHITE (-)AT EITHER SWITCH OR REAR LIGHT
Parking LampGREEN (+)AT WHITE 8 PIN CONNECTOR AT FUSEBOX
Power LockRED / WHITEDRIVER KICK
Power UnlockRED / YELLOWPANEL *
* Door Lock Wires Located In 10 Pin Connector High In Driver Kick Panel. Child Safety Locks- RED / BLUE (-) In 6 Pin Connector Above Fuse Block In Driver Kick Panel
Child Safety Locks
Accessories
Window UpD\ BLU/GRN P\ RED / BLK D\ BLU/BLK P\ RED / YEL @ MAIN SWITCH
Window DownF/ BLU/YEL F/ RED / GRN R/ BLU/RED R/ RED / BLU
Ign Key WarnLIGHT GREEN/ RED(+) STEERING COLUMN HARNESS
Trunk ReleaseN/A
OEM HornGREEN/ RED(-) STEERING COLUMN HARNESS
HeadlightsRED / WHITE(-) AT HEADLIGHT SWITCH *
OEM Alarm ArmN/A
OEM Alarm DisarmN/A
 Reversal Rest At Ground Power Window Circuit Diagram. * Canadian Models: Headlights- GREEN/ BLUE (-) At Headlight Switch.
Remote Start
Tach SignalBLACKAT IGNITER OR DIAGNOSTIC PLUG *
Ignition #2BLACK / YELLOWIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryBLUE/REDIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER WIRE
Brake LightGREEN / WHITE(+) AT SWITCH ABOVE BRAKE PEDAL
Reverse LightRED / WHITE OR RED / BLACK(+) AT SWITCH ON TRANSMISSION
Rear Window Defrost
* Igniter Located On Driver Firewall, Diagnostic Plug Located On Passenger Side Of Engine Compartment On Fuse/Relay Box. BLACK Tach Wire Also Found At Pin #20 In A White 20 Pin Connector In Passenger Kick Panel.
MO
