Need diagram for 2k3 Mitsubishi outlander
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42268
Printed Date: April 04, 2026 at 5:11 AM
Topic: Need diagram for 2k3 Mitsubishi outlander
Posted By: 2k3sxt
Subject: Need diagram for 2k3 Mitsubishi outlander
Date Posted: November 04, 2004 at 10:24 PM
I need the wiring diagram for a 2003 Mitsubishi outlander so I can install my old alarm in my fiance car. I searched the forums and only came up with a few wires. If someone could post a full diagram I would greatly appreciate it. Thanks in advance.
Posted By: snguyen
Date Posted: November 04, 2004 at 10:30 PM
Mitsubishi
Outlander
2003
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ White (+)
Ignition switch harness
Ignition  #1:
Blue/Black (+)
Ignition switch harness*
Ignition #2:
Blue/Red (+)
Ignition  #3:
N/A
Accessory:
Blue / YELLOW (+)
Brake  Light:
Blue/Orange (+)
Brake pedal switch
Tach  Signal:
N/A
Parking Lights:
GREEN / WHITE (+)
Bottom of the fuse box
Headlights:
OEM Alarm  Disarm:
OEM Alarm  Arm:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 *This vehicle may be equipped with a Transponder Anti-Theft System. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. See also Note #144
Mitsubishi
Outlander
2003
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
Blue/White (+)
Starter  Kill:
BLACK/ White (+)
Ignition  +12 Volts:
Blue/Black (+)
Dome  Lights/Superv:
OEM Horn:
Power  Lock:
LtGREEN/ Red (-)
White harness high in the drivers kick panel**
Power  Unlock:
BROWN / Red (-)
Trunk  Release:
Alarm  Input Wire:
Notes:
** See Note #201 Negative Trigger Door Locks.
Posted By: 2k3sxt
Date Posted: November 04, 2004 at 10:49 PM
Thanks for the quick reply. Do you have the info mentioned in the notes? Also when it says universal transponder bypass 2x402 what would the be the DEI equivalent? Thanks again.
Posted By: snguyen
Date Posted: November 05, 2004 at 12:46 PM
Posted By: 2k3sxt
Date Posted: November 05, 2004 at 2:45 PM
See Note #201 Negative Trigger Door Locks? I didnt see anything on a door trigger. Do you have anymore info on the triggers? Have you installed an alarm and remotestart on an outlander before? Thanks.
Posted By: snguyen
Date Posted: November 05, 2004 at 6:11 PM
All Door Trigger: Brown (-) @ White plug on front of fusebox
