1998 Durango Viper 791XV Ignition Failure
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42327
Printed Date: April 03, 2026 at 8:22 AM
Topic: 1998 Durango Viper 791XV Ignition Failure
Posted By: DDN3d
Subject: 1998 Durango Viper 791XV Ignition Failure
Date Posted: November 05, 2004 at 10:43 PM
Hi all, I hate to even post as this may have been answered but I have exhausted my searching and testing.
I installed a Viper 791XV in a 1998 Durango today. Everything works fine, except remote start. To clarify, I have a good tach signal. The database said gr/black at the coil but that produced 10-20V for me. An injector (not my number 1 choice) produced 1-6V. So I've learned the tach signal and that works ok.
The unit SHOULD (no Bitwriter, all manual) be set to Engine Checking/Tach/0.8 crank/2nd Ignition: Ignition/Accessory: On.
Now, when I activate the remote start, it cranks the engine over and no start. I've traced the problem down to the relay module not energizing the relays that turn on the Ignition and Accessory power. The starter relay works and the engine cranks, but ign/acc are not on. At this point I don't know if it is a defective module, or my mistake. However with this new-fangled integrated relay module I don't know how it could be a wiring problem.
Sorry for the long winded post, I wanted to cover all the bases. Thanks for your input.
'98 Dodge Durango SLT+
Posted By: extreme1
Date Posted: November 05, 2004 at 11:25 PM
the durango will not crank without ignition. that's interesting.
you should have energized
ign1 dk.blue
ign2 GREEN/ red (18awg)
acc BLACK/ orange
start yellow
that should get it running.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: DDN3d
Date Posted: November 05, 2004 at 11:33 PM
I don't have a GREEN/ red wire at all in the column.
Incidentally, I had this EXACT same symptom when I first started the install and I cut the ignition (blue) wire. Wouldn't start with the key. Cranked, but no start. (Probably no spark or fuel withought ign).
I have tested the relays with my DMM and they definitely don't close between constant and ignition. The only thing I didn't do, which I should have, is manually jumper them to energize the coil. I just figure if it's a defective XCRS I'll see if a local alarm shop will loan me one to test tomorrow.
Posted By: extreme1
Date Posted: November 05, 2004 at 11:38 PM
you can test the XCRS by plugging in the 4 pin harness and jumping the ORANGE / pink wires to ground and see if you get a result that way.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: DDN3d
Date Posted: November 06, 2004 at 12:24 AM
2nd Accessory and 3rd Ignition output to ground? How would that test it?
Posted By: extreme1
Date Posted: November 06, 2004 at 10:23 AM
those wires will trigger the internal relays.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: DDN3d
Date Posted: November 06, 2004 at 6:04 PM
Same wiring, new XCRS and Brain fixed it. Wish I knew which did the trick, but I am assuming the XCRS.
Posted By: DDN3d
Date Posted: November 09, 2004 at 1:47 PM
Everything is working great, but I have one nitpick. On remote starts, sometimes it fires up on the first crank, sometimes it takes 3. The first two it just BARELY blips the starter and quits. I can only assume this is because I used an injector wire for the tach signal and this is not ideal.
I got 12-20V from the BLACK/ gray ignition wire to the coil, and the brain would not learn a tach signal. Any suggestions for what to use on a '98 Durango 5.2L?
Posted By: daniel2002p
Date Posted: November 09, 2004 at 2:29 PM
that is your tach wire problem.  I would try to use the initial tach wire, and that should solve your problem of not starting right away.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: DDN3d
Date Posted: November 09, 2004 at 2:35 PM
Sorry I don't understand. What tach wire? The one for the tach in the dash? I used the gray/black coil wire but because I was getting 12-20V it wouldn't read a tach signal from there.
Posted By: DDN3d
Date Posted: November 11, 2004 at 2:22 PM
Anyone know which is the correct wire? The listed wire is NOT correct, as it shows 12-20V. The unit will also not learn this signal.
Posted By: DDN3d
Date Posted: November 15, 2004 at 12:33 PM
Anyone know? Still haven't found it.
Posted By: jaurora
Date Posted: November 15, 2004 at 1:00 PM
When I had starting issues such as above (identical). The easy fix for me was adjust the setting on the remote starter for diesal engine and allow a 10 sec. warmup time before the inital starting of the car. After that was done the car starts on the first time every time. Thinking of which, it was a dodge stratus R/T and I to also needed to use the fuel injector wire. I think the setting initally wasen't long enough, not causing the fuel to reach the injectors fast enough.
Hope this helps
MECP certified (If it really means anything)
Jeremy
Posted By: DDN3d
Date Posted: November 15, 2004 at 2:00 PM
That doesn't seem like a bad idea actually, the only problem is that the 791XV doesn't have a delay setting, only a wait-to-start wire. I could make a small circuit to delay it for 10 seconds, but that can't be the ultimate solution.
I could go into a detailed explanation of what I think is going on with the fuel injector sense wire, but that wouldn't be the point either. Hasn't anyone done a Durango and discovered that the ignition coil wire has 12-20V on it?
