1993 Infinity Q45
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42389
Printed Date: April 01, 2026 at 9:50 AM
Topic: 1993 Infinity Q45
Posted By: gechal
Subject: 1993 Infinity Q45
Date Posted: November 06, 2004 at 7:31 PM
I'm looking for a diagram for a 1993 Infinity Q45. Is it basicly a Maxima or what?
Posted By: mo12v
Date Posted: November 06, 2004 at 9:56 PM
Try this:
Constant 12 voltsWHITE/ BLACKIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ WHITEIGNITION SWITCH HARNESS
StarterBLACK/ REDIGNITION SWITCH HARNESS
Dome LightGREEN/ YELLOW(-) AT PIN SWITCH
Trunk Pin SwitchRED / WHITE(-) DRIVER KICK PANEL
Parking LampRED / YELLOW (+)HEADLIGHT RELAY UNIT OR DR. KICK PAN.
Power LockPINK/BLACKDOORLOCK TIMER MODULE IN
Power UnlockORANGE / BLUEDRIVER KICK PANEL
Negative Pulse Door Locks
Accessories
Window UpD\ BLU P\ GRN D\ GRN P\ RED / YEL
Window DownF/ YEL F/ RED R/ RED R/ GRN/WHT *
Ign Key WarnNO COLOR AVAILABLE
Trunk ReleaseYELLOW/PURPLE (-)DRIVER KICK PANEL **
OEM HornWHITE/ GREEN (-)STEERING COLUMN HARNESS OR AT RELAY
HeadlightsNO COLOR AVAILABLE
OEM Alarm ArmLIGHT GREEN(ISOLATE) BEHIND GLOVE BOX
OEM Alarm DisarmLIGHT BLUE(-) BEHIND GLOVE BOX
* Location- At Main Switch, Except For Driver Front Window Colors Which Are Located At Power Window Amp In Driver Door Or At Motor In Door.  Reversal Rest At Ground Power Window Circuit
** PURPLE (-) At Release Switch.
Negative Pulse Trunk Release
Remote Start
Tach SignalBLUE/GREENPIN 7 AT ECCS IN PASS. KICK PANEL
Ignition #2N/A
Ignition #3N/A
AccessoryBLUEIGNITION SWITCH HARNESS (HEAT-A/C)
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightRED / GREEN (+)SWITCH ON BRACKET ABOVE BRAKE PEDAL
Reverse LightRED (+)SWITCH ON PASS. SIDE OF TRANSMISSION
Rear Window Defrost
MO
