door trigger wire 2004 corolla
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42406
Printed Date: March 31, 2026 at 5:45 PM
Topic: door trigger wire 2004 corolla
Posted By: SAyeed khan
Subject: door trigger wire 2004 corolla
Date Posted: November 06, 2004 at 9:59 PM
could I use the domelight wire for the door trigger
Posted By: mo12v
Date Posted: November 06, 2004 at 10:01 PM
Dome LightRED / WHT (DR) , RED / WHT (PS) BOTH (-)AND DIODE ISOLATE **
 ** RED / WHITE (-) Driver Door in 11 Pin Conn, RED / WHITE (-) Passenger Door in 11 Pin Conn. Both Conn. Located On Top Front Of Driver Fuse/Junction Box
MO
Posted By: daniel2002p
Date Posted: November 07, 2004 at 9:29 AM
if you look in the DKP in the harness running towards the back of the car, you will find RED / YELLOW which covers all doors.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
