power door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42409
Printed Date: March 31, 2026 at 4:10 PM
Topic: power door locks
Posted By: SAyeed khan
Subject: power door locks
Date Posted: November 06, 2004 at 10:18 PM
I tapped into a nissan sentra 2002 keyless entry system but driver side lock was not locking  or unlocking . the other 3 doors worked fine . please help me.
Posted By: mo12v
Date Posted: November 07, 2004 at 11:09 AM
If it works from the Door switch, then you don't have the right wire or you don't have a good ground to wire.
If it doesn't work from door switch..check switch, motor & wires
MO
Posted By: draasch
Date Posted: November 09, 2004 at 10:23 PM
Power Lock GRAY 16 PIN CONNECTOR #201
Power Unlock PURPLE / RED IN DRIVER KICK PANEL
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
