Viper 791 and Bel radar detector
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42463
Printed Date: May 15, 2026 at 10:38 AM
Topic: Viper 791 and Bel radar detector
Posted By: kieranlavin
Subject: Viper 791 and Bel radar detector
Date Posted: November 07, 2004 at 9:11 PM
I'm wondering if there is any relation between a Viper 791 and a Bel radar detector (don't rememember the model) having false alarms? My fiancee has had the Bel detector in her old car and now her new(er) car. In the new car, I've recently had professionally installed a Viper 791. However, ever since the alarm has arrived, she's been experiencing a large amount of false alarms (across all radar bands... X, K, Ka). The only thing I can think of is that the alarm is somehow sending out radar waves? It would possibly make sense (to me of limited knowledge of these things) if it happened while the alarm was armed but this is while the car is being driven and nothing should be transmitted (the alarm should pretty much be de-activated, correct?) Is there something wrong, is this common? Any help would be appreciated. Oh, I've also tested this with my older Bel radar detector and it also sets mine off in her car. Once I put my detector back in my car, it does not false alarm (any more than was normal)
kieran
Posted By: daniel2002p
Date Posted: November 08, 2004 at 8:24 AM
You are correct, the alarm is totally off when the ignition is turned on.  It may be that the car is emitting some sort of signals.  The only way I had experienced false alarms on my radar in the future was when I installed the motion sensor (which I think is a POS), then my radar detector was going crazy with false alarms.  Other than that it is not the alarm.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: kgerry
Date Posted: November 08, 2004 at 9:04 AM
i have the Clifford 3.5 in my vehicle with a Valentine 1 and it never sets it off........ although if a cell phone rings in the vehicle the V1 freaks out and goes off.....
you didnt install something like the 508D did you?   this would certainly give you this problem......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Date Posted: November 08, 2004 at 11:27 AM
Yes, there is a motion sensor in the center console.  I'll have to try disabling that to see if it makes a difference.  Maybe pull the plugs on that and then reinstall them when you get to where you're going... then again, this is my fiancee we're talking about.  She'll forget to reinstall it!
kieran
Date Posted: November 08, 2004 at 11:28 AM
The 508D is the motion sensor, correct?
kieran
Posted By: kgerry
Date Posted: November 08, 2004 at 12:01 PM
YES... THE 508D is a RADAR Field Disturbance sensor............
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Date Posted: November 08, 2004 at 1:10 PM
Thank you very much!  I'll look into that!
kieran
