85 toyota pickup parking lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42648
Printed Date: May 14, 2026 at 10:44 PM
Topic: 85 toyota pickup parking lights
Posted By: TheevesLLC
Subject: 85 toyota pickup parking lights
Date Posted: November 10, 2004 at 2:39 AM
i'm trying to wire a 93 ford taurus, everything is working perfectly except the doorlocks.
i'm using a 451m, but it can only lock the doors. if i swap the wires, it will unlock the doors, but i cannot get it to do both.  i'm not very experienced in doorlock interfaces.
thanks for any info you might have
connor
Posted By: mo12v
Date Posted: November 10, 2004 at 8:29 AM
No sure wht this has to do with "85 toyota pickup parking lights"
Have you metered your UNLOCK wire from 451?  If U can swap the LOCK wire to Loc or UNLock, then it sounds like there is NO output from UNLock wire.
OR
You may need to use 2 SPDT Relays for stronger ground
Power LockPINK / YELLOWDRIVER KICK
Power UnlockPINK/LIGHT GREENPANEL *
* Without OEM Keyless..... Entry Reversal Rest At Ground Door Locks
With OEM Keyless .....Negative Pulse Door Locks
. It Is Common For Lock & Unlock Wire Colors To Reverse.
MO
Date Posted: November 11, 2004 at 8:38 PM
LOL sorry, i was gonna post about the 85 p/u, but somehow i lost my train of thought and asked the taurus question... anyway
no oem keyless... i suppose the 451m may be malfunctioning, but i'm sorta confused by the vehicle wiring info provided...
i've not a lot of experience with domestic doorlock systems.
Door LockPink / YELLOW Driver's Kick Panel Reverse Polarity
Door UnlockPink/Light Green W/Keyless Negative Trigger
if there is no keyless, then i'm not interested in a pink/lightgreen wire, the 451 should just connect to the pink / YELLOW wire?
