Need Remote Starter Info Nissan Sentra 94
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42694
Printed Date: May 15, 2026 at 4:01 PM
Topic: Need Remote Starter Info Nissan Sentra 94
Posted By: ThePawel
Subject: Need Remote Starter Info Nissan Sentra 94
Date Posted: November 10, 2004 at 7:25 PM
Hello, can anyone help me with wiring for a remote starter for a Nissan Sentra 1994?
Thank you,
Pawel
Posted By: mo12v
Date Posted: November 10, 2004 at 8:15 PM
Don't know if this is what U want:
Constant 12 voltsWHITEIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ REDIGNITION SWITCH HARNESS
StarterBLACK/ WHITEIGNITION SWITCH HARNESS
Dome LightRED / WHITE (-)PASSENGER PIN SWITCH OR DOME HARNESS
Trunk Pin SwitchRED(-) AT TRUNK LIGHT OR PIN SWITCH
Parking LampRED / BLUE (+)HEADLIGHT SWITCH OR DRIVER KICK PANEL
Power LockLIGHT GREEN/ BLACKIN DRIVER DOOR AT MAIN
Power UnlockSINGLE WIRE SYSTEMSWITCH/CONTROL UNIT *
* Single Wire Door Lock System- Locate And Cut L GREEN/ BLACK Wire (Doors Will Lock). Use Single Relay- Switch Side To Pin #87A, Motor Side And Negative Unlock Output From Alarm To Pin #30. Negative Lock Output From Alarm To Pin #85. 12V Constant To Pin #86. Pin #87 Not Used.
Single Wire Door Locks
Accessories
Window UpBLUE/RED SEE NOTES *
Window DownBLUE/BLACK BELOW
Ign Key WarnYELLOW/RED(+) STEERING COLUMN HARNESS
Trunk ReleaseN/A
OEM HornGREEN / WHITE (-)STEERING COLUMN HARNESS OR AT RELAY
HeadlightsBLACK/ RED (DRIVER) ANDRED / GREEN (PASS) (HI)@ LIGHT SW. (+)
OEM Alarm ArmN/A
OEM Alarm DisarmN/A
* Warning!! This Car Uses A Data Link System For Power Windows. Each Switch Is A Local Control Unit. Must Go To Each Motor Or Each Switch In Each Door.
Reversal Rest At Ground Power Window Circuit
Remote Start
Tach SignalBLUE/BLACK OR WHITEAT ECCS OR POWER TRANSISTOR *
Ignition #2N/A
Ignition #3N/A
AccessoryWHITE/ BLUEIGNITION SWITCH HARNESS (HEAT-A/C)
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightRED / GREEN (+)@ SWITCH ON BRACKET ABOVE BRAKE PEDAL
Reverse LightGREEN / WHITE(+) SWITCH ON SIDE OF TRANSAXLE
Rear Window DefrostN/A
* Electronic Concentrated Control System (ECCS) Unit Located Below Center Of Dash Behind Center Console. Tach Wires In 14 Pin Connector, WHITE At Pin #1, BLUE/BLACK At Pin #2. WHITE Wire Only Located At Power Transistor. Cold Start Wire- BLACK / YELLOW At Ignition Switch Harness.
MO
