Help installing bulldog on 03 saturn L200
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42748
Printed Date: May 16, 2026 at 7:46 AM
Topic: Help installing bulldog on 03 saturn L200
Posted By: SRWVEN
Subject: Help installing bulldog on 03 saturn L200
Date Posted: November 11, 2004 at 1:34 PM
I am going to install a bulldog RS1200E on my '03 saturn L200 sedan.  I have the wiring diagram for the car, and did some research here.  Before I begin help me with the following questions:
1.The manual shows one of the brain wires to the pink ignition wire, and on the bypass module one of the wires also goes to the pink ignition wire, is this correct and can I just splice the two together before splicing on the pink ign. wire?
2.I saw some references here about the keysense wire needing ground.  The manual mentions nothing about the keysense wire.  Should I just splice the keysense wire to the brain wire that is being grounded on a dash bolt?  There is a white wire from the brain that shows ignition negative in the manual-should that go to keysense?  I am confused what that wire does, no mention in the manual.
3.The alarm bypass module also needs a 12V constant source, can I use one of the same two that the brain is using?
4.My wiring diagram for the car shows two ACCESSORY /HEATER blower wires, one orange and one brown, which do I connect the brain to?
Thanks in advance.
Steve
Posted By: kgerry
Date Posted: November 11, 2004 at 2:11 PM
1.  yes
2. connect keysense to the status " ground out while running " of your wonderful Bulldog item
3.  yes
4. both, use a relay to power second accessory
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: SRWVEN
Date Posted: November 11, 2004 at 2:40 PM
Thanks for the help.  Excuse my newbness, what is the "ground out while running"?  I see nothing of that mentioned in the manual.  I also see you don't think much of the Bulldog.
Posted By: kgerry
Date Posted: November 12, 2004 at 10:50 AM
look for a wire that says ground when running.... all RS units have this....
i dont know where you are from, but up here Bulldog is the garbage that Wal Mart sells.... we refuse to install it at our shop......
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
Posted By: SRWVEN
Date Posted: November 12, 2004 at 11:26 AM
Since doing more research I have decided against the bulldog.  I am thinking of the valet 562T.  I have a thread on recommending a rs if you want to chime in.  Thanks
