Auto Starter install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42784
Printed Date: April 01, 2026 at 3:17 PM
Topic: Auto Starter install
Posted By: Tim1609
Subject: Auto Starter install
Date Posted: November 11, 2004 at 7:53 PM
I`m looking for a wiring diagram for my 2003 Dodge Ram P/U 4X4 Auto Diesel Reg Cab. Any help would be great.  Thanks, Tim
Posted By: daniel2002p
Date Posted: November 11, 2004 at 11:12 PM
Dodge
Ram Pickup
2002-2003
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS
Ignition  #1:
BLUE (16 AWG)
Ignition #2:
RED
Ignition  #3:
GREEN & ORANGE (2 WIRES)
Accessory:
BLACK/ WHITE & BLUE (2 WIRES)
Brake  Light:
WHITE/ TAN
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
TAN/RED
AT IGNITION COIL
Parking Lights:
PURPLE / YELLOW
HEADLIGHT SWITCH*
Headlights:
PURPLE / YELLOW
HEADLIGHT SWITCH *
OEM Alarm  Disarm:
LT. GREEN/ ORANGE *****
HARNESS COMING IN FROM DRIVER'S DOOR
OEM Alarm  Arm:
Diesel  Glow Plug:
ORANGE / Black
Powertrain Control Module***
Clutch  Bypass Wire:
Notes:
 * This Is A Single Wire System. Parking Lights Need To See A Ground (-) Through A 330 Ohm Resistor. Headlights Need To See A Ground (-) Through A 700 Ohm Resistor. ** Diesel Vehicles - ORANGE / Black Wait to Start; Tach Wire Is Gray/Black. Both Wires Are Located In A Black Connector Center Top Of Fire Wall. There Are Two Black Connectors, The Correct One Does Not Have A White Insert. *** Tach can also be located at pin 74 behind instrument cluster.
Dodge
Ram Pickup
2002-2003
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
PINK/BLACK
Starter  Kill:
YELLOW
Ignition  +12 Volts:
BLUE (16 AWG)
Dome  Lights/Superv:
SEE NOTE ***
OEM Horn:
BLACK/ RED (-)
STEERING COLUMN HARNESS
Power  Lock:
WHITE/ GREEN
DRIVER'S KICK PANEL ****
Power  Unlock:
WHITE/ GREEN
Trunk  Release:
N/A
Alarm  Input Wire:
SEE NOTE ***
Notes:
*** Separate Triggers For Each Door. The Driver's Door Trigger Is Tan (-). The Left Rear Door Trigger Is Tan/Orange (-). Both Wires Can Be Found In The Driver's Kick Panel. The Passenger Front Door Trigger Is Tan/Red (-) And the Passenger Rear Door Trigger Is Tan / YELLOW (-). Both Of These Wires Can Be Found In The Passenger Kick Panel. Diode Isolate Each Wire For Alarm Trigger With The Bands Facing Away From The Alarm/Remote Start Module. Use Only One Trigger For Dome Light Supervision. **** Single Wire Door Lock System See Note #211. Lock Requires A Ground (-) Pulse Through A 867 Ohm Resistor. Unlock Requires A Ground (-) Pulse Through A 364 Ohm Resistor. Diode Isolate One Of The Wires. ***** Requires A Negative Pulse Through A 1.5 K-Ohm Resistor.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
