Child Safety Locks How To Install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42798
Printed Date: April 02, 2026 at 4:13 AM
Topic: Child Safety Locks How To Install
Posted By: newinstaller
Subject: Child Safety Locks How To Install
Date Posted: November 11, 2004 at 10:07 PM
Hi,
I am doing a starter with keyless on a Camry 2002. Has Childs safety locks.
Installing a Compustar how would I hook that up ????
Also does the 2nd starter wire need to be hooked up?
Posted By: mo12v
Date Posted: November 11, 2004 at 10:14 PM
Constant 12 voltsWHITE/ RED OR WHITEIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ REDIGNITION SWITCH HARNESS
StarterBLACK / YELLOW AND BLACK/ WHITE AT IGNITION SWITCH HARNESS *
Dome LightGREEN/ RED (-)IGNITION KEY CYLINDER LIGHT
Trunk Pin SwitchGREEN / WHITE (-)AT THEFT DETERRENT E.C.U. **
Parking LampGREEN (+)AT THE BACK SIDE OF E.C.M.***
Power LockBLUE / YELLOW13 PIN GRAY CONN. IN DR KICK
Power UnlockBLUE20 PIN WHITE CONN.IN DR KICK ****
* There Are Two BLACK / YELLOW Wires Please Check. ** Theft Deterrent E.C.U. Is Located Behind Pass Side Dash Top Right. *** E.C.M. Located Above Drivers Kick Panel A Part Of Fuse Box.
**** First Pulse Unlocks Driver 2nd Pulse Unlocks The Rest.
Negative Pulse Door Lock Diagram.
OEM Alarm Hood Trigger:BLACK At Antitheft Module Behind The Glove Box.
Accessories
Window UpD\ GREEN P\ GRN/WHT D\ GRN/YEL P\ GRN/BLK @ MAIN SWITCH
Window DownF/ RED F/ RED / BLU R/ RED / YEL R/ RED / BLK
Ign Key WarnN/AIGNITION SWITCH HARNESS
Trunk ReleaseWHITE/ BLUE (+)AT 12 PIN WHT CONN DR KICK #232
OEM HornGREEN/ BLACK (-)AT STEERING COLUMN
HeadlightsRED / GREENAT HEADLIGHT
OEM Alarm Arm
OEM Alarm Disarm
#211-See Reversal Rest At Ground Power Window Circuit Diagram. #232-See Reversal Rest At Ground Trunk Release Circuit. OEM Horn Wire: WHITE At Theft Deterrent E.C.U. OEM Alarm Hood Trigger:BLACK At Theft Deterrent E.C.U
Remote Start
Tach SignalWHITEAT DATA LINK CONNECTOR
Ignition #2BLACK / YELLOWIGNITION SWITCH HARNESS *
Ignition #3
AccessoryBLUE/REDIGNITION SWITCH HARNESS
Neutral SafetyNON GROUNDING TYPE
Brake LightGREEN / WHITEAT SWITCH ABOVE BRAKE
Reverse LightWHITE/ REDDRIVERS DOOR SEAL HARNESS
Rear Window Defrost
 Immobilizer Bypass
(Some Vehicles Reported W/O) Omega Part:DB-PKT All Toyota/Lexis 98-02 (No Key Required). * Start Wire BLACK / YELLOW There Are Two BLACK / YELLOW Wires One Tests Like A Starter Wire The Other Like A Ignition ,Please Check.
posted_image
MO
Posted By: jrilla
Date Posted: November 11, 2004 at 10:16 PM
My notes don't mention the child safety lock issue on the 2002 and newer Camrys, but i find that odd so someone else will have to help you there. But Yes you need the 2nd starter wire hooked up for remote starters.
J Rilla
Owner/Installer
