2001 Dodge Ram Door Locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42903
Printed Date: April 02, 2026 at 5:15 AM
Topic: 2001 Dodge Ram Door Locks
Posted By: Jescism
Subject: 2001 Dodge Ram Door Locks
Date Posted: November 13, 2004 at 3:25 PM
I just installed a Dei 561R into my friends Dodge Ram and can't get the locks to work. I pulled the wires from the connector at the driver's side door harness, ORANGE / Violet and the Pink/Violet wires, and hooked them up as the "5 Wire Alternating 12 Volts Positive Door Locks" in the relay section of this site and still nothing? Can anyone help on this matter.
Also on another note I had a Viper 550 in my '03 Jeep Wrangler and switched it out to a Viper 791xv and now the Jeep will only remote start sometimes? Well maybe 10% of the time it won't start on the first attempt. Im also having this problem with the Dodge Ram but switched it to voltage sense and now it works fine. I would like to use the tach wire on bothh vehicles if I can get it to work.
Again any help that you guys can give would be greatly appreciated.posted_image
Thank you,
   Joel
Posted By: mo12v
Date Posted: November 13, 2004 at 6:30 PM
Does the Door Lock /UNLocks work with the Door Switch on the Dodge?
MO
Posted By: Jescism
Date Posted: November 14, 2004 at 5:33 AM
If you mean does the lock/unlock work after cutting the wires...then no they don't. I have the right wires...I just think I'm hooking up the relays wrong. Also When I tried locking/unlocking with the remote the fuse for the relay 12+ blew.Thought I had it hooked up backward but after reviewing my wiring everything looked like the picture.
Thanx,
Joel
Posted By: draasch
Date Posted: November 14, 2004 at 10:15 AM
sounds like you have some wires crossed.......
Power Lock ORANGE / VIOLET 16 PIN CONNECTOR IN DR. #203
Power Unlock PINK/VIOLET KICK PANEL
#203 - See Reversal Rest At Ground Door Lock Diagram.
https://wiringinstructions.com/203.htm
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: draasch
Date Posted: November 14, 2004 at 10:20 AM
01 dodge ram:
Tach Signal BLACK/ GRAY AT POWERTRAIN CONTROL MODULE *
* Power Train Control Module (PCM) Is Located On Passenger Rear Of Engine On Firewall. BLACK/ GRAY On 8.0L Engine Is 2 Cylinder Signal.(From Installer Tach Wire GRAY/BLACK)
Good Luck
David
Ace Security
813-376-9778
Tampa
Posted By: draasch
double check this wire, this is listed for the 02 jeep....
Tach Signal GRAY/WHITE AT COIL
Good Luck
David
Ace Security
813-376-9778
Tampa
Posted By: Jescism
Date Posted: November 14, 2004 at 2:38 PM
the '03 Jeep doesn't have a coil? Does that sound right? No Spark plug wires or distributor... Thanks though... I'll recheck the Dodge lock/unlock wiring
Thank you,
Joel
