2002 Maxima Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42987
Printed Date: April 14, 2026 at 10:47 PM
Topic: 2002 Maxima Wiring
Posted By: Jediknight1274
Subject: 2002 Maxima Wiring
Date Posted: November 14, 2004 at 7:42 PM
Hey out there, I'm looking for vehicle security wiring on the 02 Maxima SE including all of the automation wiring for the factory power window mods.  Locations and any tips would be great.
SMCinMD
Posted By: shadowinfector
Date Posted: November 14, 2004 at 7:45 PM
DIRECTWIRE™ WIRING INFORMATION - NISSAN / MAXIMA / 2002 / Remote Start
[PRINT THIS PAGE]
12volts      blue       +       ignition harness
Starter      BLACK/ red       +       ignition harness
Second Starter      BLACK/ white       +       ignition harness
Ignition      BLACK / YELLOW       +       ignition harness
Second Ignition
Third Ignition
Accessory      red       +       ignition harness
Second Accessory      WHITE/ blue       +       ignition harness
Keysense
Power Lock      ORANGE / black       -       driver door module
Notes: Meter these wires while turning the key in the driver door. Unlock requires a double pulse.
Power Unlock      ORANGE / blue       -       driver door module
Lock Motor      gray             pin 54 at SECU
Notes: The SECU (Smart Entrance Control Unit) is located to the passengers side of the steering column.
Unlock Motor      WHITE/ black             pin 55 at SECU
Parking Lights+      RED / blue             driver kick panel
Notes: Can also find RED / green or RED / yellow at fuse box.
Parking Lights-      lt. blue             headlight switch
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger                  SECU
Find lt. green for the drivers door in pin 1, RED / blue for the passenger front door in pin 2, and RED / white for the rear doors in pin 3. Use all 3 wires and diode isolate each.
Dome Supervision      use door trigger
Trunk/Hatch Pin      purple / YELLOW       -       pin 13 at SECU
Hood Pin      yellow/red       -       pin 6 at SECU
Trunk/Hatch Release      blue             pin 16 at SECU
Notes: Requires a high-current ground for activation.
Power Sliding Door
Factory Alarm Arm      arms with lock
Factory Alarm Disarm      disarms with unlock
Disarm No Unlock
Tachometer      WHITE/ green             instrument cluster
Notes: Located on the rear of the instrument cluster in the white plug. Do not start the car with the cluster unplugged. Can also find the WHITE/ green at the ECM located in the front of the center console on the transmission hump. The wiring is easily reached by removing the panel just to the front of the center console on the passenger side. DO NOT UNPLUG THE ECM.
Wait to start
Brake Wire      RED / green       +       brake switch or drivers kick
Parking Brake
Horn Trigger      GREEN / WHITE       -       steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module:      Required: Yes      Type: Transponder      Part #: 556U or 555U
Notes: N/A
warning
Date Posted: November 15, 2004 at 8:20 AM
Definitly a start. thanks a lot.
SMCinMD
