2002 Chevy impala alarm wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=43022
Printed Date: April 11, 2026 at 5:08 AM
Topic: 2002 Chevy impala alarm wiring
Posted By: jaurora
Subject: 2002 Chevy impala alarm wiring
Date Posted: November 15, 2004 at 9:12 AM
Can someone please help me out with a tech sheet.
Thankyou as always,
MECP certified (If it really means anything)
Jeremy
Posted By: mo12v
Date Posted: November 15, 2004 at 9:26 AM
Constant 12 voltsREDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightD BLUE/WHITE (-)B.C.M. IN DRIVER KICK PANEL *
Trunk Pin SwitchRED / BLACK (-)AT LIGHT IN TRUNK OR BCM
Parking LampBROWN / WHITE (+)AT JUNCTION BLOCK IN PASSENGER KICK
Power LockORANGE / BLACKAT BCM ON DRIVER SIDE **
Power UnlockSINGLE WIRE SYSTEMOF INST PANEL
* DARK BLUE - Pin A1 Conn.C1 Also At B.C.M In Gray Plug On Left Hand Side. (Alternate Dome Lt. Connection). ** ORANGE / BLACK Door Lock Wire Must Receive A Ground (-) Pulse Thru A 470 Ohm Resistor To Lock And A Solid Ground (-) Pulse To Unlock.
Single Wire Resistor Door Locks
Accessories
Window UpD\ D BLUE P\ L BLUE D\ D GREEN P\ L GREEN @ MAIN SWITCH
Window DownF/ BROWN F/ TAN R/ PURPLE R/ PURPLE
Ign Key WarnL GREEN (-)STEERING COLUMN HARNESS OR BCM
Trunk ReleaseL BLUE (+) *AT BCM ON DRIVER SIDE INST PANEL
OEM HornBLACK (-)STEERING COLUMN HARNESS OR BCM
HeadlightsYELLOW (-)AT HEADLIGHT SWITCH OR BCM
OEM Alarm ArmN/A
OEM Alarm DisarmLT GREEN (-)AT BCM ON DRIVER SIDE INST PANEL
* Trunk Release Alt conn:BLACK (-) At Switch Just To The Left Of The Column.
Reversal Rest At Ground Power Window Circuit Diagram.
Positive Pulse Trunk Release
Remote Start
Tach SignalWHITEAT IGNITION CONTROL MODULE *
Ignition #2D GREENIGNITION SWITCH HARNESS
Ignition #3ORANGEIGNITION SWITCH HARNESS (HVAC)
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightWHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightL GREEN (+)AT LIGHTS
Rear Window DefrostN/ATIMER BUILT INTO SWITCH
* Ignition Control Module Is Located On Top Of Engine.
GM PassLock II  ** Pass Lock Wires Are 22 Gage YELLOW,BLACK,WHITE Behind The Radio With The Ignition Wires Note : The Engine Will Not Turn Over Until The PassLock Is Connected
MO
