Wire Diagram Needed 02 Camry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=43283
Printed Date: May 11, 2026 at 2:48 AM
Topic: Wire Diagram Needed 02 Camry
Posted By: newinstaller
Subject: Wire Diagram Needed 02 Camry
Date Posted: November 18, 2004 at 2:39 PM
Posted By: snguyen
Date Posted: November 18, 2004 at 2:50 PM
ItemWire ColorPolarityWire Location
12VWHITE/ red+ignition harness
STARTERBLACK/ white+ignition harness
IGNITIONBLACK/ red+ignition harness
ACCESSORYblue+front of fuse box
SECOND ACCESSORYBLACK / YELLOW+ignition harness
TACHOMETER
POWER LOCKblue / YELLOW-driver kick panel
POWER UNLOCKblue *1-driver kick panel
PARKING LIGHTS +greenbottom of fuse box
PARKING LIGHTS -
DOOR TRIGGER*2-*2
HEADLIGHTS
WIPERS
LF WINDOW UP/DN
RF WINDOW UP/DN
LR WINDOW UP/DN
RR WINDOW UP/DN
TRUNK/HATCH PINgreen-DKP or light in trunk
HOOD PIN
TRUNK/HATCH RELEASEWHITE/ blue5widriver kick panel
FACTORY ALARM ARMarms with lock
FACTORY ALARM DISARMdisarms with unlock
HORN TRIGGERGREEN/ black-steering column
BRAKE WIREGREEN / WHITE+bottom of fuse box
LOCK MOTORblue/reddriver kick panel
UNLOCK MOTORblue/blackdriver kick panel
DISARM DEFEATblue/blackDKP, harness to rear
DISARM NO UNLOCK
DOME SUPERVISIONcomes on with unlock
SPEED SENSE
SUN ROOF OPEN/CLOSE
SUN ROOF LIMIT
LF SPEAKER
RF SPEAKER
LR SPEAKER
RR SPEAKER
RADIO 12V
RADIO GROUND
RADIO SWITCH
RADIO ILLUMINATE
POWER ANTENNA
Notes:NOTE: Some models have an immobilizer system that needs to be bypassed during remote start. Use DEI module 555F or 555U to bypass. *1 Unlock requires a double pulse. *2 The driver door trigger is RED / green at lower left of the fuse box. The passenger door is RED / green at upper left of the fuse box. The rear door trigger is RED / white at the bottom of the fuse box. Use all three and diode isolate each.
Posted By: thepencil
2002 Camry Diagram
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Posted By: snguyen
TOYOTA CAMRY 2002-03
WIRE COLORSLOCATION
12 VOLTS CONSTANT
WHITE/ RED
IGNITION SWITCH HARNESS
IGNITION 1BLACK/ REDIGNITION SWITCH HARNESS
IGNITION 2
BLACK / YELLOW (THIN WIRE)
ACCESSORY /HEATER BLOWER 1BLUE@ FRONT of FUSE BOX
STARTER 1BLACK/ WHITEIGNITION SWITCH HARNESS
STARTER 2BLACK / YELLOWIGNITION SWITCH HARNESS
KEY SENSEBLUE ( - )IGNITION SWITCH HARNESS  *1
PARKING LIGHTSGREEN (+)WHITE PLUG BOTTOM LEFT OF FUSE BOX
DOME LIGHT ( - )@ THE BOTTOM of  FUSE BOX *2
DOME LIGHT SUPERVISIONCOMES ON with UNLOCK@ THE BOTTOM of  FUSE BOX
POWER DOOR LOCKBLUE / YELLOW ( - )DRIVER KICK PANEL *3
POWER DOOR UNLOCKBLUE  ( - )(TYPE B)  *SEE DIAGRAM*
TRUNK RELEASEWHITE/ BLUE (5Wi )DRIVER KICK PANEL
TACH SENSORBLACK/ ORANGE (AC)SEE NOTES *4
BRAKE
GREEN / WHITE  ( + )@ BRAKE PEDAL SWITCH
HORN
GREEN/ BLACK ( - )@ STEERING COLUMN
FACTORY DISARM
BLUE (-)USE KEY SENSE WIRE
FACTORY ANTI-THEFT
TYPETRANSPONDER
NOTES:
*1 - Using the status output wire from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
*2 - The driver door trigger is RED / green at lower left of the fuse box. The passenger door is RED / green at upper left of the fuse box. The rear door trigger is RED / white at the bottom of the fuse box. Use all three and diode isolate each.
*3 - Unlock requires a double pulse.
*4 - On 2.4L vehicles the tach wire is at the data link connector under the driver side dash. On 3.0L vehicles it is at the Engine Control Module behind the glove box, 31 pin plug, pin 5.
