1999 acura 3.2 tl
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=43320
Printed Date: May 10, 2026 at 7:00 PM
Topic: 1999 acura 3.2 tl
Posted By: ksingh
Subject: 1999 acura 3.2 tl
Date Posted: November 19, 2004 at 5:35 AM
hey whats up guys i finished my install on this car but for some reason when i autostart the car it starts fine no problem but when i try to start the car like i would normally do wiht the key in  the ignition it wouldnt not crank,it almost as if the starter kill is in motion but if i try the ribbon from the alarm brain going to the relay pack it will start fine no problem
oh this alarm is the viper791 alarm /rs
anyone with some info on this please help me out
for some reason the purple wire on the relay pack is not gettin
Kenny
Posted By: daniel2002p
Date Posted: November 19, 2004 at 7:18 AM
can you post where you hooked up every wire on the starter kill, and also make sure that you have saughtered all the wires around the starter kill, so that everything has contact.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: ksingh
Date Posted: November 19, 2004 at 4:09 PM
hey sorry its me again but anyways i was wondering if the dei viper 791 comes with a starter kill built into that new little relay pack they got cause i am not sure if it does because today i fixed the problem i had with the car not starting with the key i hooked up the green wire to the key side and the purple wire to the starter side and then it worked fine but i tried out the starter kill and not workin so i am not sure if it has one or not
also there is another wire from the alarm brain  an orange wire which says its an armed output for optional starter kill relay would that get connect to any acc wire in that vehicle
cause when i hook that up to an acc wire in the vehicle the car wont start wiht the key
Kenny
Posted By: Velocity Motors
Date Posted: November 19, 2004 at 4:59 PM
Hey Kenny, the ORANGE wire is supposed to trigger the starter disable relay. There will be one other wire on that relay that needs a connection ( aside from the two that you have for the starter ). That is why the starter disable is not functioning properly.
Posted By: ksingh
Date Posted: November 19, 2004 at 8:11 PM
well I have the the
purple>starter
green>keyside = BLACK/ white from car harness
red >12v = white
pink > ign = BLACK / YELLOW
pink/white>2nd ign = WHITE/ black
RED / white>12v = white
orange> acc = yellow
now i know all those wire and connection is correct because when i autostart the car everything works fine and no grinding or anything like that runs fine
now there is one more orange wire which is from the H1 harness orange armed output i dont know where that wire goes too
i had it connected to the acc wire in the car but the car wouldnt start with the key and plus its like if the starter kill relay is workin there
now when i unhook that wire the car starts fine with the key and also the starter kill relay dont work
i dont know whats goin on there i checked all of my connections several times even undid the alarm and install it again and same outcome only thing i can think of is a bad relay pack is that possible please i need help asap have to get this car done for saturday morning at 11am
Kenny
Posted By: ksingh
Date Posted: November 20, 2004 at 5:15 PM
anyone has any suggestion
there is only seven wires to hook up from the relay pack to the car harness
and this is the new type of relay pack from dei
its a small box and seven wires comming out of it
above i list all the wires and what i did
just dont know where i went worng
Kenny
