2003 Dodge Caravan remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=43452
Printed Date: April 17, 2026 at 4:28 AM
Topic: 2003 Dodge Caravan remote start
Posted By: DrBriones
Subject: 2003 Dodge Caravan remote start
Date Posted: November 14, 2004 at 8:11 AM
Hi, I am going to install a new PREDATOR 4001 remote car sarter with remote power locks in my 2003 Caravan, but I don't have the van's diagram, if someone has it I would appreciate if you could share it with me.
Also I was told that all the new dodge vehicles that have a gray key they have a chip built into it that the car will detect every time you insert the key to ignite the vehicle, is that true? The owner's manual doesn't say anything about it.  The car is a 2003 Dodge Caravan SE.
Thanks in advance 8D
Roberto Briones
Ottawa, On
Canada
Posted By: jrilla
Date Posted: November 14, 2004 at 8:24 AM
Do yourself a huge favor and buy a bypasskit for the locks and the immobilizer.
Here is what I am talking about:Chrysler Bypass/Interface Combo
Thats still not a cake walk install with it but from the sound of it, it might be impossible for you without it.
J Rilla
Owner/Installer
Date Posted: November 14, 2004 at 6:32 PM
Thanks J. Rilla I have that in mind now.
Now the only thing missing is the ignition diagram... Anyone?!
Roberto Briones
Ottawa, On
Canada
Date Posted: November 18, 2004 at 5:44 PM
Hi guys, I need the diagram for my van, can u help me?  I am installinga new car starter (Predator 4001) and already have the bypass module (gray key)
I would appreciate any info.
Roberto Briones
Ottawa, On
Canada
Posted By: mo12v
Date Posted: November 18, 2004 at 6:18 PM
Constant 12 voltsL BLUEIGNITION SWITCH HARNESS *
Ignition 12 voltsPINK/WHITEIGNITION SWITCH HARNESS **
StarterYELLOW (+)IGNITION SWITCH HARNESS
Dome LightYELLOW/WHT (+)PIN 33 OF 34 PIN CONN. AT B.C.M.
Trunk Pin SwitchVIOLET/ORANGE (-)PIN 29 OF 34 PIN CONN.AT THE B.C.M.
Parking LampWHT/BRN(RESISTOR SYS.)AT HEADLIGHT SWITCH (SEE TECH NOTES)
Power LockVIOLET/D GREENAT B.C.M.LOWER LEFT OF STEERING ***
Power UnlockSINGLE WIRE SYSTEMCOLUMN IN PIN 21 WHT 34 PIN CONN.
* All Wires Are 20 Gage.L BLUE Fused At 10 Amps. For main Power Connection Connect To BROWN / RED Or WHITE/ RED Fused At 20 Amps At 6Pin Conn. At B.C.M. ** Ignition Wire Controls All Accessories. *** Chassis Ground Thru A 5.3k To Lock And Chassis Ground Thru A 2k Ohm Resistor To Unlock. ( Connector Is Third Up From Bottom Of BCM)
Single Wire Resistor Door Locks
Accessories
Window UpD\ORG/LT GRN P\ORG/TN D\ORG/D BLU P\ORG/GY @ MAIN SWITCH
Window DownF/ORG/WHT F/ORG/D GRN R/ORG/L BLU R/ORG/D GRN
Ign Key WarnVIOLET/BROWN (-)IGNITION SWITCH HARNESS
Trunk ReleaseHATCH RELEASE:VIOLET/TAN (-) THRU 1.69k RESISTER @ BCM
OEM HornD GREEN/ VIOLET (-)STEERING COLUMN
HeadlightsWHT/YEL WHT/BR ATHEADLAMP SWITCH RESISTANCE VALUE *
OEM Alarm ArmVIOLET/LT BLUE (-)PIN 14 AT 34 PIN CONNECTOR,RESISTERS
OEM Alarm DisarmVIOLET/LT BLUEARE THE SAME AS LOCK & UNLOCK BUT **
* 788-809 Ohms ** Apply In The Opposite Direction.
Reversal Rest At Ground Power Window Circuit .
From Installer: Right Slider Open/Close Chassy Ground Thru 3900 Ohm Resistor On Glossy VIOLET / YELLOW at B.C.M Right Of Steering Column. Hood Ajar Switch - VIOLET/LIGHT BLUE (-) Pin 30 White 34 pin Conn. At B.C.M.
Remote Start
Tach SignalD BLUE/D GREENPIN 11 GRAY/BLACK 40 WAY CONN.P.C.M.*
Ignition #2See Note Below **
Ignition #3
Accessory
Neutral SafetyWHITE/ LT GREENPIN 9 OF 34 PIN CONNECTOR AT BCM
Brake LightWHITE/ TAN (+)AT SWITCH
Reverse LightWHITE/ LT GREEN (+)PIN 9 OF 34 PIN CONNECTOR AT BCM
Rear Window Defrost
* Power Control Module Located Left Front Corner Of Engine Compartment. Ignition Input To Keyless:PINK/WHITE ** VIOLET/BROWN and VIOLET/ORANGE Must See 180 OHM Resistor Between Them During Start Due To Multiplexing.
Immobilizer Bypass
This Vehicle Has A Resistored Park Light System.The WHITE/ BROWN Wire Must Be Cut And A relay And Resister Must Be Used. Pin 85 To Ground Pin 86 To The WHITE Wire Of The Alarm.Pin 87A Switch Side Of WHITE/ BROWN Wire,Pin 30 BCM Side Of WHITE/ BROWN Wire. Pin 87 To One Side Of A 5.8k Ohm Resistor,The Other Side Of The Resistor To Ground. There Is A WHT/DK.BRN In The Rear Harness (Driver Kick) That Is A Pos 12v To The Tag Lights. (From Installer) From Installer: Door Lock/Unlock Wire Located On The Third Connector Up From The Bottom. ***********Door Lock And Bypass Module Available*******
MO
Date Posted: November 18, 2004 at 8:32 PM
Thanks mo12v
Roberto Briones
Ottawa, On
Canada
Date Posted: November 21, 2004 at 8:41 AM
I am installing a remote starter in my 2003 Dodge Caravan.  The Installation manual asks about Parking lights being possitive or negative trigger.  Now, I am new to installing this type of equipment, but I have installed stereos.  How do I know what kind of triggering I have? (I immagine I need the multimeter)
Also the instructions ask about the door locks being possitive or negative.  How do I determine it?
Thanks in advance.  I know this questions are easy for everybody that is familiar with installing this equipment!
Roberto Briones
Ottawa, On
Canada
Posted By: MJA1962
Date Posted: November 21, 2004 at 8:49 AM
Dodge
Caravan
2002-2003
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
YELLOW (NOTES BELOW)
IGNITION SWITCH HARNESS**
Ignition #1:
PINK/WHITE
Ignition #2:
N/A
Ignition #3:
N/A
Accessory:
N/A
Brake Light:
WHITE/ TAN
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
PURPLE / ORANGE (AC)
GRAY CONNECTOR BY IGNITION MODULE
Parking Lights:
WHITE/ BROWN (-)
AT HEADLIGHT SWITCH***
Headlights:
OEM Alarm Disarm:
VIOLET/LT. BLUE
AT PLUG AT PCM ON FIREWALL DRIVER'S SIDE******
OEM Alarm Arm:
VIOLET/LT. BLUE
Diesel Glow Plug:
N/A
Clutch Bypass Wire:
N/A
Notes:
* Many Of These Vehicles Are Equipped With A Transponder (Even If The Key Is Black). Use Universal Alarm Bypass Module Part Numner 2x402 Where X Can Be Any Number. ** NOTE!!! A Second Start Wire (PURPLE / Brown) Needs a relay installed to provide a ground (-) through a 180 Ohm Resistor during crank in order to remote start the vehicle, See Installation Note #162. ***The parking lights are negative trigger through a 2.1K ohm resistor. ****All DesignTech remote starters except the 2xx22 have an ignition 3 output - it is the WHITE/ black in the 'control harness'. This wire will be used to control the bypass module, if needed.
Dodge
Caravan
2002-2003
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
RED
IGNITION SWITCH HARNESS (MAX # AMPS)
Starter Kill:
Ignition +12 Volts:
PINK/WHITE
Dome Lights/Superv:
BLACK/ WHITE (-)
AT 4 PIN PLUG NEAR FUSE PANEL
OEM Horn:
GREEN/ PURPLE (-)
STEERING COLUMN HARNESS
Power Lock:
PURPLE / GREEN
AT PLUG AT PCM ON FIREWALL *****
Power Unlock:
PURPLE / GREEN
Trunk Release:
VIOLET/TAN
AT PLUG AT PCM ON FIREWALL DRIVER'S SIDE ******
Alarm Input Wire:
BLACK/ WHITE (-)
Notes:
*****for the 2001-02 Caravan Lock is negative trigger through a 5.3k ohm resistor. Unlock is negative trigger through a 2.0k ohm resistor. For the 2003 Caravan Lock is negative trigger through a 2.2k ohm resistor. Unlock is negative trigger through a 390 ohm resistor. The Body Control Module (BCM) is in the driver kick panel near the the parking brake, ******See Installation Note #211. A Single Pulse Of Ground Through A 2.2 K-Ohm Resistor Will Open The Liftgate. POWER SLIDING DOORS: Violet/Dk. Blue Wire At Switch. Driver's Side - A Single Pulse Of Ground Through A 2.7 K-Ohm Resistor. Passenger's Side - A Single Pulse Of Ground Through A 1.5 K-Ohm Resistor. ****** To disarm the OEM alarm a negative trigger through a 9.20k ohm resistor.
DesignTech International, Inc.
Tel: (703) 866-2000 Fax: (703) 866-2001
©2002 All Rights Reserved
7955 Cameron Brown Court
Springfield, Virginia 22153 USA
1-800-DESIGNTECH
(1-800-337-4468)
www.designtech-intl.com
DesignTech disclaims any liability or responsibility arising out of any inaccuracies of this information or use of this
information for installations or otherwise. Please verify all wiring for accuracy prior to making any connections.
Posted By: MJA1962
Date Posted: November 21, 2004 at 8:54 AM
Posted By: jrilla
Date Posted: November 21, 2004 at 9:06 AM
Parking lights are positive and the wire is WHITE/ Orange in the loom of wires to the left of the e brake.
Locks are a negative single wire system that requires resistors.
without a security system: Lock is 4.7K ohm and Unlock is 1.8K ohms on the PURPLE / Green wire (pin 21)
With Security system Unlock is b/w 7.5K ohm and 10K ohm, and Lock is b/w 1.8k Ohm and 2.3K ohm on PURPLE / blue wire (pin 14) Unlock requires double pulse. These wires are located in the 3rd plug from the top at the BCM.
Just so you know there is a 2nd starter wire in that vehicle and it is negative through a 180 ohm resistor.
This not an easy vehicle for a first time starter install. So be sure to read up really good and get yourself a good wire diagram. Also you should seriously consider getting a bypass module and a doorlock interface to make the installation much easier. Trust me its worth the extra money to get them.
Look here for what I am talking about:
03 Caravan Products
J Rilla
Owner/Installer
Date Posted: November 21, 2004 at 4:21 PM
Thanks guys.  You have been very helpfull.  I already have the bypass module (haven't installed it yet).
Now, in the installation manual they talk about the "glow plug light"... what is that?  And also for the interior light illumination output they talk about a relay which I haven't found.  do i have to buy one?  where do i install it if so?
thanks  So far I think I am doing well.
Roberto Briones
Ottawa, On
Canada
Posted By: gus1
Date Posted: November 22, 2004 at 3:34 PM
Glowplug light is only necessary on a diesel.... and, unfortunately, we won't be getting any of the diesel powered Caravans in North America any time in the near future. Too bad really.... they go like hell, and get 42ish MPG while they're at it.
Gus
Date Posted: November 22, 2004 at 3:42 PM
Thanks Gus!  That was starting to be a real pain in the  *ss
Roberto Briones
Ottawa, On
Canada
Date Posted: November 22, 2004 at 5:11 PM
Does anybody know where to find it (heater A/C color) in a 2003 Caravan?
Roberto Briones
Ottawa, On
Canada
Posted By: swamprat323
Date Posted: November 22, 2004 at 5:16 PM
ACCESSORY|*11
*11 Accessory is not required for remote start.
that all my info says
Posted By: IMAGE6902
Date Posted: November 24, 2004 at 2:29 PM
this is a very complex install for a beginner, may want to rethink having professionally installed. recommend using relays for anything having resistors (lock/unlock/2nd start wire) also recommend soldering all resistors. test lock/unlock resistors with vehicle at rest and while running, if resistance isn't close enough, while running the locks may not work. spent alot of time myself under the dash of these multiplexed nightmares, so have fun....
I tell it like it is...
Date Posted: November 24, 2004 at 5:51 PM
Hi again, I can't seem to find the wire that monitors the vehicle's RPM.  The Instruction manual says it is the one that in idle it measures 1-5 volts in AC (volts) and increases by 1-5 when RPMs increase to 3,000-4,000 RPMs.  I haven't found it.  The diagram that I have for my car (2003 caravan) says it is very accessible in the PCM PIN 11 of the 40-pin connector and the color matches, but it just doesn't measure what the install manual says.  Another diagram that I have says it is a completely different cable color that also exists in that harness, but not very accessible, and doesn't measure wnat tha manual says.
If someone could please tell me which one is I would appreciate it.
Roberto Briones
Ottawa, On
Canada
Posted By: daniel2002p
Date Posted: November 24, 2004 at 6:06 PM
the easiest way is to go to one of the fuel injectors, and use the odd colored wire.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: Ravendarat
Date Posted: November 25, 2004 at 11:37 PM
I second that, just strip back the tape on two injectors and they will each have two wires, on each injector one wire will be the same color, use the other color at either injector.
