Used Car Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=43486
Printed Date: April 12, 2026 at 7:09 PM
Topic: Used Car Remote Start
Posted By: Concours
Subject: Used Car Remote Start
Date Posted: November 21, 2004 at 3:43 PM
Bought a used Ford T-Bird it has a remote start made by Delta Vehicle Security. The car will not start starter turns and cranks just not enough to start. Any have a manual for one of these remote start. There is not a model # on the unit. THANKS !
Posted By: daniel2002p
Date Posted: November 21, 2004 at 4:32 PM
what year is the t-bird, you may need to reprogram the key bypass.
------------- 2005 Toyota Corolla S
1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: Concours
Date Posted: November 21, 2004 at 7:12 PM
It's a 1987 no anti theft system. no chip in the key,
I just cranks for 2 sec and needs to crank a little longer to start the car.
Date Posted: November 21, 2004 at 8:17 PM
can you locate a vallet swith in the car?
1.8L VVT-i I-4
Posted By: jrilla
Date Posted: November 21, 2004 at 9:00 PM
maybe take a picture and post it. A picture of the remote might do too.
------------- J Rilla
Owner/Installer
Posted By: Concours
Date Posted: November 21, 2004 at 10:16 PM
here is a pic of the remote I will post a pic of the unit later tonight
Posted By: jrilla
Date Posted: November 22, 2004 at 9:38 AM
you need to locate the brain, there should be a little door on the top that slides open to reveal 4 dipswitches. Turn #3 OFF to increase crank time.
I have heard that you need to remove power from the unit for the change to take effect. This may or may not be the case. it cant hurt to unplug it though to be sure. You can just unplug the 2 red wires and also disconnect the 10 pin connector then flip th dipswitch and then plug the wires back in.
Owner/Installer
Posted By: Concours
Date Posted: November 22, 2004 at 9:42 AM
Here is a picture of the control unit
Posted By: jrilla
Date Posted: November 22, 2004 at 9:48 AM
well thats different than what i thought, but the remote is exactly the same as what I have seen. It looks there are 4 dipswitches though. One is Tach/Tachless, one is vacuum/hoodpin, one is normal crank/extended crank, and one is diesel/non diesel
Owner/Installer
Posted By: Concours
Date Posted: November 22, 2004 at 10:30 AM
Dip switch settings are
1 vacuum sence
2 increase crank time
3 for diesel
4 spark plug wire sence or coil sence
Wires on control unit
1 Black = Ground
2 Brown sensor bypass to sensor trigger wire
3 Blue sensor bypass to alarm sensor trigger wire
4 Gray Ground out when remote is active
5 White Brake input positive
6 Blue/White Hood Pin Switch negative
7 Orange reciever input negative
8 Green spark plug wire sence dip switch # 4 must be off
9 12 volts out to parking lights
10 Purple 12 volts out to starter
11 Orange 12 volts out to acc
12 Yellow 12 volts out to ignition
13 Red power input 12 volts
As it is now dip 1,3,4 are on and 2 is off.
Can some tell me wher all the wires go half of them are not hooked up. THANKS !
