Adding a glass break sensor to Viper 300ESP
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=4360
Printed Date: March 29, 2026 at 3:17 PM
Topic: Adding a glass break sensor to Viper 300ESP
Posted By: yobtah
Subject: Adding a glass break sensor to Viper 300ESP
Date Posted: October 11, 2002 at 6:28 AM
I'm planning to install a Viper 300ESP and I'd like to add a glass break sensor. I'm assuming I can connect it to the alarm brain's "optional sensor harness". I'm wondering about operation of the inputs. The connector has four wires. The connector uses two multiplex inputs and the brain expects an input of longer than 0.8 seconds to trigger the alarm. I'm guessing if glass breaks, the noise won't continue for 0.8 seconds. Will this be a problem? Does the glass break sensor provide a continuous output if it's triggered? I would think the connector would be designed to work with a glass break sensor, but the length of the trigger event seems odd. I'd appreciate any information anyone can give... thanks.
Posted By: Ohmz
Date Posted: October 11, 2002 at 6:43 AM
I haven't installed a Viper ES 300 in a while, but what I remember the harness is made for a shock sensor. The alarm just needs to read a pulse. It doesn't matter how long the trigger. The alarm will continue to go off as usual. If you can't connect to the harness you should connect it to the blue wire... I think thats usully the optional trigger sensor wire.
------------- My Personal Installer Note: Connectors are easy, neat, and professional. But do you know how to crimp properly?
Posted By: yobtah
Date Posted: October 11, 2002 at 6:51 AM
Oh... I think you're right about the blue wire. The 300ESP has a built-in shock sensor, so I doubt that's the purpose of the optional harness, but the blue wire is for an instant trigger sensor. That makes more sense. Thanks.
Posted By: Ohmz
Date Posted: October 11, 2002 at 7:28 AM
No problem...  ------------- My Personal Installer Note: Connectors are easy, neat, and professional. But do you know how to crimp properly?
Posted By: Ohmz
Date Posted: October 11, 2002 at 7:32 AM
no problem!  ------------- My Personal Installer Note: Connectors are easy, neat, and professional. But do you know how to crimp properly?
