2004 malibu wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=43813
Printed Date: April 06, 2026 at 8:16 AM
Topic: 2004 malibu wiring diagram
Posted By: twistofcane2000
Subject: 2004 malibu wiring diagram
Date Posted: November 26, 2004 at 9:02 AM
 hello people, i am gonna be installing an omega alarm this weekend was wondering if  any body had the wiring diagram for this model car? any help would be great thanks!
Posted By: snguyen
Date Posted: November 26, 2004 at 5:06 PM
MALIBU 2004
WIRE COLORSLOCATION
12 VOLTS CONSTANTBATTERY on the LEFT SIDE of the ENGINE COMPARTMENT
IGNITION 1PINK (+)IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER BROWN (+)IGNITION SWITCH HARNESS
STARTERSee NOTE ****
PARKING LIGHTS ( - )BROWN / WHITEat the HEAD LIGHT SWITCH
DOMELIGHTGRAY ( - )at the BCM, Plug C3, Pin A10     See NOTE *
DOOR TRIGGERSee NOTE **
POWER DOOR LOCKWHITEat the BCM, Plug C1, Pin 66       See NOTE *
POWER DOOR UNLOCKSAME WIRE (1500 ohm Resistor Required)                 See NOTE *****at the BCM, Plug C1, Pin 66       See NOTE *
TACH SENSORSee NOTE ***
BRAKE
WHITE ( + )at the BCM, Plug C1, Pin  24      See NOTE *
TRUNK RELEASE BROWN / WHITE ( - )at the BCM, Plug C1, Pin  71       See NOTE *
TRUNK TRIGGERORANGE / BLACK   ( - )at the BCM, Plug C1, Pin  18       See NOTE *
HOOD TRIGGERPINK/BLACK ( - )at the BCM, Plug C1, Pin  69       See NOTE *
HORNTAN ( - )at the BCM, Plug C2, Pin  14       See NOTE *
ALARM DISARMWITH FACTORY REMOTE ONLY
FACTORY  ANTI-THEFT
GM's PASSKEY 3Requires part # 791 bypass module and extra key
 NOTE *     The BODY CONTROL MODULE ( BCM ) is part of the FUSE/ RELAY BOX on the FRONT PASSENGER SIDE of the CENTER CONSOLE. The BCM has (4) FOUR Plugs C1,C2,C3 and C4.
NOTE **    This vehicle has (4) FOUR DOOR TRIGGERS. The DOOR TRIGGERS are: DRIVERS DOOR GRAY/BLACK ( - ), PASSENGER DOOR TAN/WHITE ( - ), LEFT REAR DOOR LT. BLUE/BLACK ( - ) and the RIGHT REAR DOOR LT. GREEN/ BLACK ( - ). Use all (4) FOUR and DIODE ISOLATE when connecting to an ALARM.
NOTE ***  The TACH wire on the  2.2L is a WHITE or ORANGE and on the 3.5L it is a  PURPLE or ORANGE / WHITE at the IGNITION CONTROL MODULE.
NOTE ****     The STARTER wire is NOT REQUIRED for REMOTE STARTING, when the BCM sees the IGNITION ON and the ACCESSORY wire lose voltage, it will automatically crank the starter.
NOTE *****    This vehicle uses a (1) one wire door locking system, and requires a (-) Negative (type "B") pulse to the WHITE wire to LOCK and a (-) Negative (type "B") pulse thru a 1500 ohm resistor on the same WHITE wire to UNLOCK. The doors must be closed for the keyless entry to operate. Relays are required if the unit DOES NOT have on-board relays to operate the door locks.
Posted By: snguyen
Date Posted: November 26, 2004 at 5:07 PM
Chevrolet
Malibu
2004-2004
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
SEE NOTES BELOW*
SEE NOTES BELOW*
Ignition  #1:
PINK
Ignition #2:
SEE NOTES BELOW*
SEE NOTES BELOW*
Ignition  #3:
N/A
Accessory:
BROWN
Brake  Light:
WHITE (+)
Found at BCM Blue plug**
Tach  Signal:
Parking Lights:
BROWN (+)
Found at BCM Red plug**
Headlights:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 *MUST USE Vehicle specific bypass module 23571. Please call sales department to order this part. **BCM (Body Control Module) is located in the center console passenger side fuse/relay box.
Chevrolet
Malibu
2004-2004
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED / WHITE
OEM Alarm Disarm:
FACTORY REMOTE ONLY
Dome  Lights/Superv:
GREY (-)
OEM Horn:
TAN (-)
Found at BCM Large Grey plug**
Power  Lock:
WHITE (-)
Please see note below***
Power  Unlock:
SINGLE WIRE (-)
Trunk  Release:
WHITE/ BLACK (-)
Alarm  Input Wire:
GREY (-)
Notes:
**BCM(Body Control Module) is located in the center console passenger side fuse/relay box. The connecters are a Blue plug, Large Grey plug, Red plug, Small Grey plug.). *** Refer to installation Note #211 for diagram. The Lock wire negative trigger. Unlock is negative trigger 1.5K ohm resistor. Lock/unlock wire are found at the BCM Blue plug.
Date Posted: November 26, 2004 at 5:39 PM
thanks alot  snguyen!  really appreciate the help.
Posted By: pken
Date Posted: November 26, 2004 at 8:37 PM
hi snguyen,
could you please also post a wiring diagram for Hyundai Elantra 2002? I'd like to see if it's the same wiring diagram i got from commandocaralarms.com. I'm still not sure about the door lock/unlock wire -- the diagram says: blk/org or blue for lock (same wire for unlock).
Ken
