98 plymouth neon wires
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=43863
Printed Date: April 07, 2026 at 8:25 PM
Topic: 98 plymouth neon wires
Posted By: richardic
Subject: 98 plymouth neon wires
Date Posted: November 26, 2004 at 9:49 PM
hi,
I have a 98 Plymouth Neon and here on the CD of 12Volt show me : ignition #1, ignition #2 and Ignition #. what is it?
I want to find the color for:  +12v ; ACC ; ON ; START
please can anyone help me before I make any mistake?
thank you
Posted By: draasch
Date Posted: November 26, 2004 at 9:51 PM
Make:   Plymouth
Model: Neon
Year:    1998
This Database Was Last Updated On:    9/16/2004
Index #: 1205
Alarm
Constant 12 volts PINK/BLACK & RED IGNITION SWITCH HARNESS
Ignition 12 volts D BLUE IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light YELLOW (-) AT ANY PIN SWITCH *
Trunk Pin Switch GRAY/BLACK (-) AT LIGHT IN TRUNK
Parking Lamp BLACK / YELLOW (+) AT HEADLIGHT SWITCH **
Power Lock PINK/VIOLET BLUE 16 PIN CONNECTOR #203
Power Unlock ORANGE / VIOLET IN DRIVER KICK PANEL
* YELLOW (-) Wire Is Also Located In A GRAY 20 Pin Connector Behind The Driver Dash. ** BLACK / YELLOW (+) Wire Is Also Located In A GRAY 20 Pin Connector Behind The Driver Dash. #203- See Reversal Rest At Ground Door Lock Diagram.
Remote Start
Tach Signal GRAY/L BLUE AT POWERTRAIN CONTROL MODULE *
Ignition #2 BLACK/ ORANGE IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory BLACK/ WHITE IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light WHITE/ TAN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light VIOLET/BLACK (+) AT SWITCH ON TRANSMISSION
Rear Window Defrost N/A TIMER BUILT INTO SWITCH
* Powertrain Control Module Is Located On Driver Strut Tower
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: November 26, 2004 at 10:03 PM
can you fill the right color here for me please?
posted_image
+12v =
ACC =
ON  =
START =
and on starter (motor) which wire sould I get from the relay?
thank you
Posted By: draasch
Date Posted: November 26, 2004 at 10:09 PM
+12v =Ignition #2 BLACK/ ORANGE IGNITION SWITCH HARNESS
ACC =Accessory BLACK/ WHITE IGNITION SWITCH HARNESS
ON =Ignition 12 volts D BLUE IGNITION SWITCH HARNESS
START=Starter YELLOW IGNITION SWITCH HARNESS
Good Luck
David
Ace Security
813-376-9778
Tampa
Date Posted: November 27, 2004 at 12:17 PM
thank you very much
the 87a and the 30 on Relay they go to the same function?
because the Start (on ignition) goes to the STARTER (motor) right or wrong?
because on STARTER (motor) have 3 diferents wires and I don't know which one to chose, and if on ignition the Start is the same as on STARTER (motor) will save me time ? right or wrong?
I'm just trying to sntall by my self!! its easy but before ask then make any mistakes
thank you guys
Date Posted: November 27, 2004 at 1:05 PM
thank you very much David
